I
imported_craigyjp
So today I installed a BT kit for Scott Francis in his A4, Scott had already installed an RNS-E and parrot kit, I removed parrot kit and installed the Audi OEM BT kit and coded it up for his car.
Paired with a Motorola Razor V3 (Black) it worked like a charm, SIM access profile and full integration, BT module installed behind GB and Mic in the normal roof position.
Here are the screen shots...
Main Dialer screen...
Accessing Phone setup options....
Accessing the SIM over BT....
Firmware verion H50 and SW0360...
When BT connects you get this message and the Bling...
When you make a call from your phone....
When making a calll from the Phone Directory...
All in all, better quality than the Parrot kit and no ugly bits on the dash.
Craig
Craig
