    Mar 2013
    Staines
    Double din to single din?
    A3 1.8T 2001, post facelift
    I've got the BOSE Symphony installed. But I've got a great Kenwood single-din stereo (BT92SD) from my old Astra lying unused. Is it possible to fit a single din cage and a pocket in the double din space? Any idea what problems (if any) I'm likely to face?
    Jun 2003
    World of my own
    9,813
    With the Bose system you really are better off sticking with the stock HU. No one does a double DIN conversion fascia for the 8L, so you'd have to buy the A4 version and modify it. You'll also need an RCA input adapter PC9-408 to link to the Bose amp but this can cause a nasty popping from the Bose sub, which means you'd have to use the hideous PC9-410 hi to lo converter adapter which will destroy the quality and introduce alternator whine. So it's not a great move unless you upgrade the speakers and bypass the Bose amp.
    Alex Turner
    Mar 2013
    Staines
    Ok, thanks for the advice. Going to stick with the Symphony. The cassette isn't that offensive, and the Bose audio is still a cut above my old system.
  1. S3 double din to single din conversion
    By <tuffty/> in forum In-Car Entertainment
    Last Post: 7th November 2011, 14:07
  2. 2003 S3 Double Din to Single Din Fascia
    By SWAMP DONKEY in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2010, 13:28
  3. Double din to single DIN
    By Effect in forum In-Car Entertainment
    Last Post: 28th April 2007, 00:05
  4. double din to single din.
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2007, 13:53
  5. Double DIN to single DIN adapter
    By AndyMac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2006, 08:58
