Sky InsuranceChris Nott
Results 1 to 1 of 1
    Jan 2012
    Central Scotland
    40
    Enable A2DP on Fiscon BT unit
    May have been posted before but took me a while to find this out.
    Out of the box Fiscon bluetooth unit does not have A2DP enabled so music can't be streamed to your stereo.
    I thought it was a problem with my coding and went through set up many times with no luck but it is set up of the Fiscon unit.
    Once installed and coded to your vehicle you wil have an option of "A2DP start" on the DIS from MFSW controls but it does not do anything.
    To solve:
    With ignition on and phone connected dial *582#4001. This enables A2DP function.
    Turn off ignition and wait 5 minutes then try to stream music.
    Source: Tronix - Fiscon Bluetooth module with A2DP
  1. S6/A6 sender units
    By Kevshann in forum General Technical / How To
    Last Post: 6th May 2003, 14:58
  2. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
  3. New head unit and DIS
    By [Dave B] in forum In-Car Entertainment
    Last Post: 29th January 2003, 21:57
  4. Phat noise unit?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 18:33
  5. Power Supply Unit - Sony VCR
    By Joshie in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 8th January 2003, 15:45
