Chris NottJMB Retrofits
Results 1 to 14 of 14
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Using stock speaker wiring? (A4 B6 avant)
    Chaps
    I have the standard system in my car with sub/amp in the back.
    Are all 4 door speakers + sub powered by the amp?
    And if I replace the amp, can I use the stock wiring to power the stock speakers? and then eventually replacement speakers in the stock locations?
    27,121
    Standard meaning non Bose?
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    hi mate yeah
    Jun 2003
    World of my own
    9,813
    You can use the stock speaker wiring no problem - obviously you can't use the power connection to the rear amp to power a new amp
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Cheers Andy - will the stock speaker cable take 50wrms?
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    I might run my own wiring actually? Is it easy to run the wiring through the gromits into the doors?
    Im not going for bass or component sets in this car. Just a cleaner sound over stock.
    Ive bought 2 sets of 17cm Infiniti 6532i. And will be running off a 4 channel DLS CA40 amp.
    Jun 2003
    World of my own
    9,813
    good luck with that! There's no way through the A pillars to the doors. The rubber boots are protecting solid connectors for all the door wiring.
    With the standard (non Bose) system - the fronts run off the HU on a standard ISO plug annd the rears run off the rear amp.
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Thanks Andy and understood - I shall forget the running my own wires idea..
    I think im best to leave the fronts running from my Sony Headunit then?
    Then run the rears from my own amp leaving 2 channels (bridged) potentially for a small sub at a later date..
    Just sold a 8" RE sub that would have worked perfect in this car! Nevermind..
    I have also learnt the reason why my rear speakers/sub doesnt work - I have an aftermarket HU!
    This is not an issue considering my plans but the fact I can only pick up radio 2 and classic fm is an issue!
    Q****What do I need to 're-activate' my aerial amp?
    Jun 2003
    World of my own
    9,813
    You just need to fit an ISO aerial amp adapter and wire the blue flying lead to the power antenna lead on the new HU.
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Great thanks Andy
    27,121
    It is a possibility to run new wires tbh, time consuming but maybe possible, dependent if there are spare slots in the door connectors, which there usually is.
    if you want to do this with an oem finish then open up the pillar rubber boots, see if the connectors have any spare holes to put repair wires into, if so, you could look at the sizes available for that connector & fit new audi repair wires into each connector side, join new speaker wires onto the audi ones, thus oem connection through the connectors properly.
    This isnt a 5 minute job & if the stock wires are adequate then use these tbh.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Thanks maybe il take a look as I done something similar to your suggestion in my previous BMW.
    Do you know if the stock speaker cable will take 50wrms?
    Jun 2003
    World of my own
    9,813
    Yes no problem
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Thanks Andy
  1. Speaker wires in doors.
    By quattrojames in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th October 2009, 22:32
  2. Rear speaker wires?
    By Allen in forum In-Car Entertainment
    Last Post: 26th June 2009, 23:50
  3. Front Speakers Wiring
    By AndrewUkR6 in forum In-Car Entertainment
    Last Post: 1st January 2009, 17:54
  4. Audi 'Stock' Speaker Size??
    By PNH80 in forum In-Car Entertainment
    Last Post: 12th August 2008, 08:48
  5. rear speaker wire colours
    By AJO in forum In-Car Entertainment
    Last Post: 23rd October 2006, 13:32
