Chris NottEM Tuning
Thread: '04 A3 Set Up
    Feb 2012
    20
    '04 A3 Set Up
    Hi guys.
    I'm thinking of upgrading the system in the A3 so just wondering what set up they run as standard? i.e. front speaker size, rear speaker size...also am I right in reading these already have a small sub/amp fitted? Does this amp run the rear speakers and sub?
    Ideally I'll be fitting a new HU, front components with rear coax's both run off an amp and then a sub with separate amp in the rear...any comments on this set up or anything I'll need to be aware of?
    Any advice appreciated.
    26,775
    Depends on whats fitted, bose etc, if bose then all speakers run from the amp back right quarter, with a sub on the left quarter.
    Andymac does an aftermarket sub to fit in the same oem place.
    Feb 2012
    20
    Thanks for the reply.
    It's all Bose at the moment but contemplating a complete overhaul. I'll look into Andys sub, thanks.
    Jun 2003
    World of my own
    9,813
    The fronts are 6.5" components with 1" tweeters and the rears 6.5" coaxials in the 3 door, (components in the sportback rear doors)
    You'll need fitting adapters for all of them.
    I do MDF ones (just search ebay for Audi MDF) or you can use the plastic ones from any web based outlet.
    http://freepdfhosting.com/a6b33703ba.pdf
    http://freepdfhosting.com/feb70e5d1d.pdf
    With the Bose system you really have to replace everything in one go, as the speakers are all low impedance 1.5ohm units and the Bose amp doesn't really like driving anything else.
    You'll also need an antenna amp adapter, ISO or Fakra depending on whether you have a single DIN or Double DIN Audi HU. On an 04 it's probably ISO
    Alex Turner
  1. Window Settings Lost
    By kchow in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd October 2003, 07:38
  2. Max Turbo Boost Revo settings
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 14:54
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. TT pedal set part numbers
    By ooooaudi in forum TT/TT-S/TT-RS Forum
    Last Post: 9th April 2003, 20:20
  5. tt pedal set part numbers
    By ooooaudi in forum General Technical / How To
    Last Post: 9th April 2003, 20:16
