AH FabricationsVolks Autos
Results 1 to 11 of 11
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    Help needed installing the Kufatec and Alpine KCE 425i. Wales ideally but can travel
    Hi Im looking for someone to install the items pictured which ive bought off ebay. Saved a fortune but have no idea on how to install. I have the latest RNS-E fitted to my 2007 A3.
    Ideally if there is someone in the South Wales area or reasonable travelling distance? Any advice/help appreciated.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I could be wrong, but I think you are missing two important cables from that set of parts.
    1, the IR lead, probably the most important, were that white cable is with the 3.5mm jack on it there should have been a long lead with a 3.5mm plug on one end and the flat two pin connector on the other end. This allows the RNS-E to control the KCE-425 via the IMA.
    This is the control line IMA Control Wire - Stereo Jack 3.5 - Version 2-35552
    2, the RCA AV lead, a RED/Yellow/White 3 way lead to connect the video output of the KCE to the inputs of the IMA, they are always missing from the kits and can be bought for a few quid easily enough.
    https://www.google.co.uk/shopping/pr...ed=0CFUQ8gIwBQ
    You should get these before any installation is attempted
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    Craig
    Thanks for the advice. I thought the red yellow and white cable was missing. Didnt know about the other though.
    Hopefully someone on her can put me in touch with an installer and ill order the extra cables.
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    Looking on the alpine site the highlighted cable seems to be missing from what i have. Any ideas what it is?4.jpg
    26,747
    Last time I checked with Kufa, they said their ima wasnt compatible with the mk2 rns units, maybe they've rectified this now or were talking crap.
    I maybe have a job down the M5 & in Swansea to do, so I maybe able to do it.
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    I checked their website and thought it was compatible but ill have another look. (dont really know what im looking at TBH)
    If you do go to swansea let me know, Im in Merthyr Tydfil which isnt far out of the way.
    thanks
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    The Kufatec website shows the following: Is the mk1 the RNS-D and MK2 RNS-E or are there a new and old RNS-E?
    IMA, Integrated Multimedia Adapter allows you to connect to multimedia devices through the following Sat/Nav systems:
    • Volkswagen MFD
    • Volkswagen MFD-2/RNS-2
    • Volkswagen RNS-510
    • Skoda Nexus 4:3
    • Skoda Nexus 16:9
    • Seat Naviagtion 4:3
    • Seat Navigation 16:9
    • Audi RNS-E
    • Audi RNS-D
    • Lamborghini Gallardo
    • Ford MFD 4:3
    • Mercedes Command 2.0
    • Mercedes Command 2.5
    Easy installation due to automatic head unit detection
    The following options can be configured through the head unit:
    • Contrast
    • Saturation
    • Color
    • Picture Orientation
    The following devices can be connected to the IMA:
    • DVD - Player
    • DVD - Changer
    • DVB - T
    • Playstation
    • HDD
    OEM TV-Tuner is not required
    26,747
    There is a mk1 & mk2 rns-E.
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    Ah. Ill try emailing them to check.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The cable your high lighting is the standard IR cable that comes with the KCE-425, it is not used in the installation with the IMA, but there is one in the box. So probably why it's also missing from your purchase. it is replaced by the first cable I mentioned in my reply.
    I have fitted an IMA to a MK2 RNS-E and I also have the reverse camera IMA working with my own MK2 rns-e.
    Daz395's Avatar
    Jan 2011
    Merthyr Tydfil
    49
    Thanks Craig.
    Ill order the 2 missing cables then hopefully can get it all fitted.
  1. A3 juddering problem :( Help needed by the audi brainers
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2013, 09:31
  2. Help needed which rs4 injectors and FRV for the 2.0 tfsi part numbers/advice
    By AARON77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 18:36
  3. Help needed installing interior parts please :-)
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th June 2011, 13:00
  4. Bit of help needed on the 225 4wd please !!!!!
    Last Post: 1st June 2011, 17:08
