Sky InsuranceBadger5
Results 1 to 8 of 8
    Jan 2013
    16
    HELP aftermarket headunit insall with bose
    hey,
    i have a a4 avant b6 trying to install after market radio i have the bose harness with rca i just cant get it to power up.
    on the audi 8 pin i have a brown which is earth i guess and red/blue green/blue and two small bown wires what goes to what lol
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    You will have to run a switched live from the ACC in the fuse box to make it power up.
    The A4 B6 has a perm live, ground, K-line (blue/green), BOSE (brown) and possibly the DWA (brown)
    Jan 2013
    16
    Quote Originally Posted by s8craig View Post
    ohh right. what sort of cabe can you use for the switch live. and also iv read the two small brown wires i leave out.
    cheers mate..
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The switched live can be anything really, about the same as the brown wires would suffice. Yes you do not need the K-line (blue/green) or brown thin wires for the aftermarket system.
    Jan 2013
    16
    ok thank you very much. i just read you can get a switch live feed from the cigarette light on center console or theres a red wire under the steering column have you heard of that
    cheers
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Cigarette lighter sockets are usually perm live in an Audi B6. I would go to the fuse box on the right of the car or the steering column. There are lots of perm lives around in your car so be careful you do pick a switched live.
    Jun 2003
    World of my own
    9,813
    There are switched lives but these will turn off when you kill the engine, there is only one (as far as I could find) proper accessory feed that stays live until you pull the keys out and yes that is under the steering column
    Wiring in a proper accessory feed (ignition on) for aftermarket HU install
    Alex Turner
    Jan 2013
    16
    hey all thanks for all the posts that have been very helpful .
    i have install the hu plus a reverse camera it was all successful until ....lol
    well there was me driving along with the radio on then i indicate right i hear the tic toc in the speakers lol so i guess i tapped into the wrong red wire under the steering column. haha
  1. Aftermarket head units with BOSE system
    By a3james in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2012, 20:14
  2. Wiring aftermarket headunit with rear bose
    By valentn in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2012, 20:25
  3. Fitting aftermarket headunit into S3 with Bose
    By LukeTripod87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2011, 22:58
  4. Bose with aftermarket headunit
    By vetch in forum In-Car Entertainment
    Last Post: 26th April 2009, 16:55
  5. Replies: 4
    Last Post: 17th November 2008, 13:40
