JMB RetrofitsSky Insurance
Results 1 to 13 of 13
    Jul 2011
    12
    audi concert ii diversity aerial
    Hi Guys ive an 2006 audi a4 b7 with concert ii single din full bose and factory ipod dock i will be removing this and fitting a pioneer avh8400bt once the fascia adaptor comes the issue i have is what kind of aerial adaptor do i need to solve the issues with the diversity aerial ive seen adaptors for the symphony which are dual fakra. but i have not come across anythng for the concert ii which seem to be a standard plug and a fakra plug ill attach a pic of the standard radio showing both sockets white and yellow. anyone have any ides what to do ?
    Jun 2003
    World of my own
    9,813
    Just use the ISO lead, you don't need the diversity aerial
    Alex Turner
    Jul 2011
    12
    Thanks Andy. So the reception will be just as strong without it ? even with the de-mister? (this used to affect my bmw)
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    You need to ensure the radio can generate phantom power to power the antenna booster, if it cannot then you may need a widget to provide +12v down the antenna wire.
    Jul 2011
    12
    But wouldn't the yellow fakra have to be connected somehow to The new radio to do this ? What would be a good 12v wire to connect to ? I have seen a phantom double fakra connection for retrofitting the rnse but does any company make something that will work for me ?
    Jun 2003
    World of my own
    9,813
    You just need an ISO aerial amp adapter, and connect the blue flying lead to the power antenna lead on the new head unit.
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    Alex Turner
    Jul 2011
    12
    Thanks Andy i have just ordered one. You seem to know what you are talking about so i have another question, i bought the CTKAU02 fitting kit i have full Bose is the harness plug N play or do some of the pins have to be swapped around ?
    Jun 2003
    World of my own
    9,813
    Are you sure you have a single DIN Concert (thought they were all double DIN quadlock on the B7)
    If you do have a single DIN Concert then not sure why you bought the CTKAU02, as that includes a Quadlock harness and from the image above your system is clearly ISO - all single DIN Audi HU's are ISO
    Alex Turner
    Jul 2011
    12
    yeah im sure its a single din bought a double din frame and climate control in order to fit the double din pioneer.
    Take a look it has both the quadlock and iso harness i bought it as a kit worked out cheaper (this is what i will be using harness with brown rca's) just not sure if it is 100% plug and play ?
    Jun 2003
    World of my own
    9,813
    Yes it should be. You won't have a switched ignition live though, not sure if that adapter will give you CANBUS emulation so you may need to wire both up to the perm live or wire in a switched live
    Alex Turner
    Jul 2011
    12
    Apparently it is compatible with the canbus system it has a little box (far right on the picture) that is supposed to hook up to it so Im hoping this will give ignition live and illumination. Is there anything else the canbus adapter should control ?
    Jun 2003
    World of my own
    9,813
    No just power and steering wheel controls if you have them
    Alex Turner
    Mar 2012
    369
    The canbus interface I got delivers GALA (speed controlled volume) and illumination as well as ignition and reverse gear outputs
  1. Audi S4 (2003) Diversity Aerial issues??? HELP PLEASE!!!
    By Lion Heart in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th December 2011, 13:38
  2. Audi Concert CD Changer
    By Fozzie in forum In-Car Entertainment
    Last Post: 18th November 2011, 08:41
  3. Audi Concert CD Changer
    By Fozzie in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2004, 09:03
  4. Audi Concert (Fiiting CD Changer)
    By JaceyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2004, 08:45
  5. Audi concert stereo
    By MarcA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 09:39
