Chris NottVolks Autos
    Sep 2005
    Derbyshire
    180
    Ipod to Concert or Aftermarket H/U?
    Hi Guys,
    I have a 1999 S3 1.8T and was recently given a 1st gen iPod.
    I'm looking to use this with either the standard Concert unit (Concert 2? As it has the 6 disc changer in the boot) or an Aftermarket H/U.
    Having looked at the xCarlins etc i'm not overly happy with reviews i've read of them, especially considering the price of them.
    Would I be best to get an aftermarket H/U (with a rear USB connector) so I can just stick the iPod in the glovebox and forget about it, or is there another way of doing things that i've overlooked?
    26,720
    Dension/connects2 is another route
    Sep 2005
    Derbyshire
    180
    The connects2 doesn't appeal as it doesn't use the Charging port of the iPod, the reason I was given it, is due to it not holding charge for more than an hour so would like to keep it permanently connected.
    26,720
    The connects2 I used years ago used the main port for everything iirc, so should be fine unless they've chnaged to a different system with headphone jack now, but cant imagine so.
    Sep 2005
    Derbyshire
    180
    So they do! How did you find the sound and general useability of the Connects2 system? Can you control the iPod via the standard H/U?
    26,720
    It was a while back when I had my S3 tbh mate, but yes it was controllable via ipod, it may have gone forward/backward tracks, but ideally fit with easy access to see tracks & select on ipod itself.
  1. Replacing Concert with aftermarket unit -n00b!
    By Naj in forum In-Car Entertainment
    Last Post: 25th September 2011, 22:36
  2. 2010 S3 Concert Radio - aftermarket ipod integration
    By Lex696 in forum In-Car Entertainment
    Last Post: 9th July 2010, 09:45
  3. Connect ipod to Concert I stereo question
    By RobW in forum In-Car Entertainment
    Last Post: 19th February 2010, 23:39
  4. Ipod into Concert?
    By A3DOL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2009, 22:10
  5. ipod with concert II
    By ginner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2005, 17:03
