AH FabricationsJMB Retrofits
Results 1 to 9 of 9
    Jul 2011
    46
    blue tooth fitting kit
    I HAVE A 2004 A6 ALLROAD BOSE FRONT AND BACK, IS THERE ANY COMPANY OUT THERE THAT DOES A HARNESS TO ALLOW ME TO FIT A PARROT KIT ?
    27,029
    What head units fitted?
    Jul 2011
    46
    Blue tooth
    It has the sat nav unit it displays mmi on start up rne s I think
    27,029
    Why not fit the audi BT system, I can supply fit this, send me a PM if interested
    Jul 2011
    46
    I have a parrot blue tooth kit from my last car so was looking for a quick fix, I have to do the timing belt and water pump service as its hit the 70000 mark so I am in for a bit of a wallet bashing . I am sure what your offering is in the hundreds ?
    27,029
    It would be unfortunately.
    You would need to provide the mute wire & NF +/- wires into the quadlock connector.
    Whereabouts are you located as maybe can fit for you?
    Jul 2011
    46
    Northern Ireland , I am sure I am not a half hours drive away !!!
    27,029
    Urmm that maybe tricky, lol.
    Trying to think whose able to do over your side, are you fairly technically minded as you'd need +/- & the nf/mute wires connected, rest I hazard a guess is pnp for the parrot, so you'd only really need the repair wires to use in quadlock for nav unit & then join the +/- to the current nav units, soldering preferable with heatshrink.
    Sep 2012
    61
    Give JustCarKits a call up, he should have the Connector in stock or should be able to easily make one up for you.
    http://www.justcarkits.co.uk/
  1. blue tooth
    By daveoly in forum General Chat
    Last Post: 7th August 2009, 15:39
  2. Factory Fitted Kit vs Aftermarket
    By RS84 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2008, 12:01
  3. Bailey FK96 + fitting kit for sale
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2008, 17:49
  4. H7 xenon retro fit kit on vag parts
    By waveform2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2005, 15:56
  5. Fitting blue tooth hands free
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2004, 22:50
