Volks AutosSky Insurance
    brasiliangringo's Avatar
    Mar 2010
    544
    Symphony 11 radio code generator help...
    Per title, can any help me generate the code please ?
    Sep 2012
    61
    Does the radio belong to the audi? Or is it a replacement? If it is the original disconnect the battery on the car for 10-15 minutes, as the symphony should then re-code it's self to the car.
    if not, PM me over the serial number and I'll dust off the old code generator.
    Mar 2010
    544
    Cheers buddy, am waiting for the serial number then will buzz it across - is it true the last 4 digits are the code ?
    Replacement - it doesnt belong to the Audi but when installed in the donor car, it never displayed a SAFE mode after being unplugged for around 20 mins..
    Does that mean they lock when you place a donor in the recipient car as never knew that ?
    27,093
    When connected to a different car/vin it requires pin, if you plug into last registered vin it recalls this & doesnt usually ask for pin.
    Mar 2010
    544
    That explains a lot, thought i was going around the bend.. thanks.
  1. Audi Symphony Radio Code
    By nokia_aid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 10:52
  2. Symphony radio code
    By Mini-mad-matt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th February 2008, 20:15
  3. radio codes? please help
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2005, 15:16
  4. inputting Symphony 2 radio code?
    By ImS3ola in forum In-Car Entertainment
    Last Post: 12th April 2005, 20:02
  5. Audi A4 Symphony headunit for sale with radio code
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 25th October 2004, 23:40
