Badger5AH Fabrications
Like Tree1Likes
  • 1 Post By Stutibs
Thread: Hi all dis problem
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    Hi all dis problem
    Hi guys and gals,
    I've done a search over what appears the entire Internet to no avail.
    I have a symphony 2 in my 8l a3 but the buttons don't illuminate and the dis does not display the radio info.
    I have a code on vagcom for the radio for comm fault and one for the cluster or comm fault radio. I'll post the exact code up later.
    Can someone please point me in the right direction.
    Many thanks
    olly_s3 likes this.
    Jun 2003
    World of my own
    9,813
    Does the unit work otherwise?
    Have you added it, or is it original to the car?
    Facelift A3's use the CANBUS to tell the unit when the ignition is on/off and feed info to the DIS, so it's definately a CANBUS issue.
    Alex Turner
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    Hi all dis problem
    It works otherwise yes although after an hour it turns itself off. It's as if the car isn't running. As far as I know it's standard to the car.
    27,089
    If its turning of after an hour, then I'm also with Andy, its a canbus connection issue as thats a symptom & feature for oem radio's that arent being told when to turn of as such, so saves battery, check wiring & errors.
  1. RNS-D retrofit DIS problems
    By cerips in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st April 2012, 10:58
  2. Bluetooth / DIS problem
    By stucker in forum General Technical / How To
    Last Post: 11th October 2011, 18:12
  3. DIS problem. Any help please
    By gary3306 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th October 2010, 17:26
  4. just upgraded to full DIS, problems??
    By bugwhizz in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th August 2009, 10:51
  5. DIS Problem or Not
    By Fuzzman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2005, 16:00
