    Richardlkay75's Avatar
    May 2012
    Audi Concert - Speakers crackling B7 A4 Avant
    Hey guys
    I currently have an issue with my B7 A4 Avant whereby the speakers will crackle intermittently. It's not caused by anything specific eg; bumpy roads or cornering etc, just as and when it feels like it. It's been getting progressively worse over the last week or two to the point this morning that the system would crackle, then blast out on top note, then go quiet for a few seconds before slowly returning to normal.
    I had the head unit out yesterday and checked all the connections behind there and all is OK as far as I can see. I've also checked the connections on the amp and sub speaker in the boot and again, all appears to be OK. I've yet to disconnect the amp and just power up the HU to see if this makes any difference.
    It's a completely standard OEM install. I've tried searching but it's not bring up much (maybe that's just me!)
    Thoughts/suggestions please.
    Ta
    B7 A4 Avant 2.0 TDi SE - Phantom Black|LED DRL's
    Jun 2003
    World of my own
    9,813
    Is it a Bose system or non Bose.
    The Bose amp suffers from the main solder joints drying out which will cause this issue, usually worse on cold mornings, improving when the amp has warmed up.
    Non Bose then you need to check the connectors on the A pillars behind the rubber boots between the door hinges as these can get "electrically dirty" and cause intermittant break up, but this is usually resolved by jacking up the volume.
    Alex Turner
    May 2012
    Hi AndyMac
    It's a non Bose system. I'll check out the connectors as suggested. Cheers
  1. Replies: 0
    Last Post: 28th April 2012, 22:47
  2. sony changer to concert stereo - crackling
    By adamgroves in forum In-Car Entertainment
    Last Post: 1st July 2004, 21:41
  3. Audi Concert (Fiiting CD Changer)
    By JaceyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2004, 08:45
  4. upgrading 1998 BOSE Concert speakers
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2004, 21:28
  5. Audi concert stereo
    By MarcA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 09:39
