Volks AutosAH Fabrications
Results 1 to 7 of 7
    Jul 2012
    Enfield
    21
    no front speakers
    Evening all,
    Just drove home from work when my front left speaker started cracling and making all sorts of noise as if the terminal was coming loose. This was doing this with the steroe on or off and intermitantly.
    When i got home on further inspection i found the front left and right speakers are not working with only the left one making these noises, the front center one still works fine.
    The car is a b7 a4 avant with ehe syphoni 2 bose system. Has any one got any ideas what this could be as it drives me mad all that noise. Thanks
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,647
    no front speakers
    I'd be looking for a loose connection on the rear of the unit or the Bose amp.
    Currently rolling in a SKODA!!!
    Jul 2012
    Enfield
    21
    Fingers crossed do you know how its wired up ie head unit to amp then to all speakers??? and are they fused?
    Jun 2003
    World of my own
    9,813
    More likely to be the Bose amp starting to fail - they suffer from dry solder joints which causes all kinds of wierd electrical noises, usually worse first thing on a cold morning.
    HU to amp then to all 9 speakers. There's a main fuse but that won't be the cause
    There are connection blocks behind the rubber boots between the doors and the chassis which sometimes get dirty but this will make the speaker intermittant and if you jack up the volume it usually resolves the issue.
    Alex Turner
    Jul 2012
    Enfield
    21
    Just a update about this problem, its all working wahoo.
    I took out the amp and put the circuit board in a tray of rice and covered in rice for 24 hours (incase there was moisture ) thus the green corroction on the terminals.
    I secondly resoldered the points from the main connection.
    Unfortunatly i did not do one at a time to see what had actuly fixed the problem as just really wanted it fixed but thank god its all working now.
    Jun 2003
    World of my own
    9,813
    Nice one, zero cost fix that's what we like!
    Alex Turner
    Arrkon's Avatar
    Oct 2010
    1,647
    no front speakers
    Quote Originally Posted by AndyMac View Post
    Agreed, always pays to be handy with a soldering iron
  1. a3 front speakers
    By Masterm8fo in forum In-Car Entertainment
    Last Post: 19th April 2005, 10:03
  2. Part number for Bose front speaker
    By Kapten in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2004, 22:58
  3. Front speakers causing vibration?
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2004, 16:11
  4. How easy 2 remove front speakers?
    By fallmonk in forum In-Car Entertainment
    Last Post: 15th September 2004, 22:16
  5. Upgrading Front Speakers
    By 1600sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2004, 17:20
