AH FabricationsJMB Retrofits
    GavConner's Avatar
    Jan 2006
    Cleckheaton
    52
    Move from RNS-E to Chorus with multi changer - CD wont load ?
    Good morning all
    I've got a few questions about a move from RNS-E to Chorus with multi changer
    The Chorus radio works perfect, the multi changer works great but the head unit CD won’t work. It won’t load or accept CD’s
    There’s no error codes and no CD stuck inside the unit as if the CD button is pressed it says “No CD”
    Questions ….
    Is there a special way to select the head unit CD option and not the multi changer ?
    As the car had a RNS-E in it will the Vag com or car software need changing ?
    Is there anything else I need to do to reset the CD player to accept CDs ?
    Thank you for your help !
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    Quote Originally Posted by GavConner View Post
    Good morning all
    Good morning
    I'm under the assumption the CD Changer is the external kind in the glovebox? If so then to access the CD Changer from the Chorus unit you press the CD button twice, which should display as 'CDC' on the radio display.
    It shouldn't do, unless when the RNS-E was installed, the 56-Radio was removed from the CAN installation list. The coding is stored in the stereo so if you had the stereo plugged in previously, then it should work fine.
    There could be a adaptation channel coding for the radio that is preventing the use of CD's.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    GavConner's Avatar
    Jan 2006
    Cleckheaton
    52
    Hi mate, thanks for the reply
    Just to confirm ..... the issue is with playing the CD's in the head unit and not the multi changer.
    Multi changer works fine.
    Do I need to do anything to make the head unit accept the CD as when they are offered to the unit it dosnt suck them in
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It should work regardless of ANY coding!!!!
    My guess is the CD player is faulty, simples
  1. Replies: 0
    Last Post: 24th October 2007, 15:32
  2. VAG-COM - Moving from 8L to 8P
    By RGS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2007, 01:00
  3. Moving from Diesel to Petrol
    By chrisfrancis in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd March 2006, 20:54
  4. moved from Michelin PS2s to Eagle F1 GSD3 - initial thoughts
    By imported_CurryMilkShake in forum Handling
    Last Post: 13th March 2006, 09:32
  5. Just moved from a scooby to an S3
    By leemclaughlan in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2005, 23:26
