Volks AutosChris Nott
Thread: Radio Problems
    Westy_A3T's Avatar
    Dec 2010
    335
    Radio Problems
    I have the standard cassest/radio in my '99 A3 but starting a little over a month ago the stations have gone to pot. My biggest problem though is it no longer picks up my ipod through an adaptor. I got it going 2 weeks ago for 2 minutes then it went beep-beep-beep.... Any ideas? Is it to do with the analog signal going?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Analogue signal will not be going any time soon. 2016/17 maybe before switch off. So that is not your problem. More like is that the antenna amp is failing hence the lack of signal. Do you have a bee sting antenna on the roof? Usually it is the base of that antenna that fails.
    Westy_A3T's Avatar
    Dec 2010
    335
    Yeah i have the bee sting. Radio 1 keeps changing to BBC Cambs but only in mornings
    27,129
    & if its the bases I know of they're not cheap either.
  1. HELP!! Symphony II to Symphony II+ Strange Radio Problem
    By BennyB0Y in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2009, 15:46
  2. Radio problem
    By Steve B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st July 2007, 00:24
  3. Radio problems
    By Les 51 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2007, 19:41
  4. A6 Avant radio problem
    By fjtwelve in forum In-Car Entertainment
    Last Post: 20th June 2006, 18:41
  5. Aftermarket radio problem with VAG-COM?
    By Dean_T in forum In-Car Entertainment
    Last Post: 5th September 2004, 18:11
