Sky InsuranceAH Fabrications
    Dec 2011
    396
    fitting rca leads to a standerd audi head unit ?
    hi there i wont to keep the standerd look but need a minium of 1 set of rca leads can it be done or amd i better of getting a cheap head unit with red front
    Jun 2003
    World of my own
    9,813
    Depends on the model/age of HU. All Audi HU's have front & rear pre-outs, they are just not on standard RCA connectors. Some are on mini ISO and later models are on Quadlock. Easiest method is to tap the rear pre-outs at the rear amp or sub depending on what you are going to be using them for.
    The BLAU adapter (PC3-11) provides front and rear RCA's for ISO HU's (all Audi single DIN HU's are ISO as well as pre-2005/6 double DIN). However you have to unplug the existing feed to the rear amp (or Bose amp if you have Bose) in order to connect it.
    Mini ISO Yellow 6 pin pre-outs to RCA Sockets online at Nexxia UK
    So depends what you are doing as to the best method.
    Alex Turner
  1. Does Audi Bluetooth only work with an Audi Head Unit??
    By dalepearson in forum In-Car Entertainment
    Last Post: 18th June 2011, 08:17
  2. Audi Concert Head Unit to fit A3, A4, A6
    By bhavin1986 in forum For Sale/Wanted - Audi Parts
    Last Post: 11th May 2011, 23:38
  3. Which Audi Head unit?
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th October 2008, 11:20
  4. Audi Head unit removal pins???? are they the same???
    By imported_alecblack in forum In-Car Entertainment
    Last Post: 28th January 2006, 13:42
  5. Cack Audi head unit
    By imported_Daren_28 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2004, 15:44
