Volks AutosEM Tuning
Results 1 to 1 of 1
    Oct 2012
    59
    advise on connection issue ipod dock in glove to rns-e/concert II+
    Hi,
    i recently upgrade my concert II+ to a rns-e and everything worked fine including ipod and steering-wheel controls exception the aux-in as i needed to use a adaptor for this so i brought this morning
    i used the keys to remove the rns-e and unpluged the gps, anatana and main connector, after this i figured out which pins i need to disconnect for the aux-in from the main connector and realised that i needed to extend the cables as this not long enough so i connected the single one i had removed back again.
    after i connected back i tested the stereo and it worked fine along with steering-wheel controls, but could not find the ipod bit under media when i pod connected, the ipod displayed accessory connected but nothing on the rns-e.
    i therefore decided to check connect my old concert II+ which i knew 100% worked with ipod as i used this for last 3 weeks, when i connected this back i had same thing displayed on ipod - accessory connected and when i selected cd in the concert i could not select the cd-charger bit as it would show the ipod, i also noticed the ipod screen would change from accessory connected to normal and a few times while i was trying to figure out whats wrong.
    i need abit of advise on where on the connection block the ipod accessory connects to so i can ensure it is connected properly, i have uploaded a picture of the wiring diagram of concert II+
    any advise would be great.
    thanks
    dee
  1. Is this an iPod dock in my glove box?
    By .Jas. in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd October 2012, 21:26
  2. Ipod dock (fit in glove box)
    By TM in forum For Sale/Wanted - Audi Parts
    Last Post: 4th June 2012, 00:01
  3. Audi glovebox iPod dock not working with RNS-E
    By Az in forum In-Car Entertainment
    Last Post: 26th August 2011, 23:17
  4. How do I connect an iPod to my TTG 910??
    By noodle in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 31st July 2006, 20:46
