Sky InsuranceEM Tuning
    Oct 2009
    London
    79
    Sub Power Amp Install
    Guys
    I'm going to be picking up a 57 plate A6 Avant (C6) soon (non Bose) and want to use my Kenwood mono amp to drive a sub keeping the OEM MMI stereo setup (don't want to change the head unit). Is this possible? Is there a separate RCA pre-out for the existing sub? (I've noticed that there is a sub level control on the MMI)
    TIA
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    If your C6 is anything like my B7 then you can either use a hi-lo converter (tapping into the speaker wires) to convert to an RCA, or the rear channels may already be pre-outs (to the rear amp) and just need tapping into and converting to RCA connectors. Hi-Lo converter is the most fail-safe way, doesn't matter if you have bose or not then, will still give you the volatge RCA output you're after. I did the same for my sub install
    Someone asked a similar question to this about the 5.0 HU, quick search should do you
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
  1. Power amd amp install and MMI
    By linners in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 24th October 2012, 13:47
  2. A3 Non Bose Sub & Amp Install - Confused
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2009, 15:01
  3. s3 sub and amp install
    By S3ren in forum In-Car Entertainment
    Last Post: 31st January 2008, 09:55
  4. mounting sub and amp
    By Jay in forum In-Car Entertainment
    Last Post: 29th September 2006, 15:03
  5. FS: Audi OEM Bose Sub (including amp)
    By comdw in forum In-Car Entertainment
    Last Post: 13th June 2004, 11:14
