Sky InsuranceChris Nott
Results 1 to 12 of 12
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Will Coding Work?
    I've had a Pioneer HU installed that's supposedly CANBUS enabled, but there's no radio\track info showing in the DIS! Apparently the HU is also capable of showing Climate & Parking sensor info on screen for VW & Ford, so I can't see why it wouldn't also work for Audi.
    Will coding via VCDS enable DIS info or am I doomed to look at a blank upper display 90% of the time?
    Thanks.
    P.S: It's This One BTW.
    2009 A3 SB 2.0T DSG S line
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Re: Will Coding Work?
    I dont think it will take any coding to begin with because its aftermarket.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Quote Originally Posted by SL11 CKK View Post
    I meant the car mate! can the car be coded to read\display the HU info?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    I think the HU will have worked from the begining if it was going to. There is nothing that needs coding on the car to accept it IIRC.
    I bet the can bus compat is more to do with it turning on and off via can bus without additional wiring / add on modules
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I don't think it will work at all, climate and parking can information is comfort can BUS, but the radio stations etc are infotainment BUS.
    Chances of it working? zilch
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    an image of the rear panel of the HU:
    Will the highlighted socket not be of use for this ...he says clutching at straws.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yeah, it will be useful for connecting a CD changer which is what it is designed for, nothing else
    27,106
    IP-Bus can use an ipod adapter aswell if the head unit supports the adapter, which I suspect it will.
    But 1st, have you got the main connector wiring list to see if this has any bus wires at all to utilise, have you spoken to pioneer to speak about the climate etc features & are there any setup menu's within the unit for these systems to work.
    I'm little skeptical it will work but hey I'm all for new things
    Ironically I was in discussions with RT about the protocols used on mk5/6's for head units & the dis, so if it works on vw's it may not work on audi's tbh mate.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Hi Nigel,
    I went online and had a look at Pioneer's manuals for the unit & it's showing the fly lead that's on the back of my unit, but not in my CD borne manual, so it must be a late addition! I've highlighted it in RED again!
    The Online manual is Here, page 8 is where I've captured the image from. The plug is a little white male (I think) 2 or 3 pin affair. Haven't spoken to Pioneer as yet, I thought I'd give real experts a go first. lol
    I'm glad your the type that likes a challenge, as my list of woes is growing! earlier today I had a reversing camera fitted & that's giving me issues too, But I'm not sure if the car battery needs a charge so I'll try that tomorrow - If that doesn't cure it, I may need you to fly in sooner than expected & deliver that VCDS cable personally.
    27,106
    Well you need a seperate adapter it clearly shows anyway to interface with cars bus, but which bus is it needing, kinda vague, hence why I said ring pioneer technical mate, it wont be a coding thing on the car imho, it will be a pioneer thing.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Okay mate, will do probably tomorrow! I'll post the result of said phone call when I know anything.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Contacted Pioneer Tech support this afternoon, but spoke to a young fella that couldn't grasp what a Info Display is! He claimed they don't do any leads for A3's, but I know they do because they supplied the Steering Wheel Remote patch lead with the HU I got directly from them.
    I'll try again tomorrow, hopefully I'll get through to someone that has a clue.
  1. Vag-com Cable for 2003 S3 - Will this work?
    By [Dave B] in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th January 2007, 15:59
  2. will this work in my A3
    By Herby1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 10:25
  3. To the technical minded out there Will this work
    By gidimille in forum General Technical / How To
    Last Post: 2nd January 2006, 01:30
  4. Vag cable for Golf - will it work in the S3?
    By jazz_2004 in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th February 2005, 23:31
  5. Spax suspension kit for a 1.8t will it work on 1.6
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2004, 16:21
