Badger5EM Tuning
    Dec 2005
    Aberdeen Scotland
    15
    Speed Pulse wire
    can neone please tell me where i can locate the speed pulse wire?
    I had this apline sat nav installed in my previous car and i am gonna install it in my audi now. just need to locate this wire.
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: Speed Pulse wire
    what car do you have?
    On my 100 it comes off the gearbox by the driveshaft.
    Cage's Avatar
    Oct 2004
    95
    What Audi and year do you have? If it is pre can-bus, then you should be able to locate the speed pulse in pin.1 of the ISO plug.
    Dec 2005
    Aberdeen Scotland
    15
    its an audi a3 1.8t x-reg (2000) mate
    Dec 2005
    Aberdeen Scotland
    15
    Bump [img]/ubbthreads/images/graemlins/confused.gif[/img]
    imported_craigyjp
    Pin 31 of the Blue 32 pin connector behind the dash, manual says it white/blue but n ours it was white/green
    Remove the cluster and take out the blue connector, splice into the the wire at pin 31.
    Craig
