Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    chasdrury's Avatar
    Jan 2005
    Sheffield, UK
    259
    Fitting Sat Nav RNS-e to A4
    Hi guys
    I have a 2004 A4 with double din already, so, to fit SatNAV (DVD version) what do I need - I am assuming the unit with a disc, GPS atenna and do I need any wiring harnesses or anything? Also, will directions display on my DIS or do I need another box to do this?
    Final Question and the most important really, will my phatnoise still work with this RNS-e unit?
    Chaz
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    Re: Fitting Sat Nav RNS-e to A4
    You should PM craig for info. Search for posts in this section on his Sat nav fitting service....
    imported_craigyjp
    Sent you an email.
    Craig
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    Craig,
    I'm also quite interested in this. Could you shed some light. Thanks in advance.
    imported_craigyjp
    B6 & B7 A4's really easy to do, hardest part is installing the the GPS receiver somewhere.
    Everythng will still work, CD/phatnoise/Telephone/BOSE
    Only thing that woint work after an upgrade is the TV if you have one, that will need a new tuner.
    I can supply and fit the units for you, coded for your cars tyres/dash/ICE etc
    12 months warranty
    Craig
    Jul 2005
    scotland
    397
    how hard is it to instal the gps receiver?
    imported_craigyjp
    Not too difficult, it needs good line of sight of the sky, without obstruction from metal. Some people put them on the dash I prefer them under the dash above the glove box on an A4, or behind the cluster on an A6.
