Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Maxumo's Avatar
    Mar 2011
    Cardiff
    88
    Help Me Get Aux On My Concert (pics inside!) can anyone in S.Wales code?
    Right ive got a Concert with iPod integration and I'm looking to also have an Aux Input
    I bought this but realised my iPod connection takes up the slot, I removed the iPod connection and tried the new aux just to see if it works and it didn't - I also disconnected the aux input and connected into the iPod connection that also didn't work is it at all possible?
    A3 S Line 170 Phantom BlackPearl
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    In your Ipod plug (blue) you should see the three pins empty that match up to your pins on the new white connector, you need to move them over from the white plug to the blue one.
    Use a very small screwdriver to remove the black insert from the white connector and then gently push in the holding pins and each wire should slide out.
    Move the wires over to the black part of the blue plug by removing the black section out and inserting the pins into the empty holes.
    I think i said this in the first thread you made, the radio needs coding to enable the AUX port, until you have that done you will never see the AUX input.
    Coding
    0?x0xxx:
    Options 3
    +1 = Analog Input (AUX)
    +2 = Multifunction Steering Wheel
    +4 = Telephone
    Maxumo's Avatar
    Mar 2011
    Cardiff
    88
    Yeah I did that, didn't realise it needed coding though
    Anyone in South Wales that can code?
    Thanks for the help dude
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I used the words "has to be enabled" in my post, which was referring to the coding. Sorry if that wasn't clear.
    27,129
    Not sure of help, but I maybe in bristol on saturday, if you wanted to pop over, also cirencester & stroud over weekend.
    Maxumo's Avatar
    Mar 2011
    Cardiff
    88
    I had someone do it for me today thanks anyway!
    Jul 2012
    17
    Hi there is your concert cd player same as mine?
    Maxumo's Avatar
    Mar 2011
    Cardiff
    88
    No mine was the double din
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Thats the same as mine, am waiting to see my local retrofit guy about sorting mine out - shud be this week, will let you know......
    2.0 tdi 220 Quattro.....
    Bigfish tuning remap, S-line half Leather heated seats, Bose sounds, Elec' fold in heated mirrors, tyre pressure monitors, Charcoal roof linning, Mfsw,phone prep, 18" Speedlines, Dual climate, total open/closure remote windows,L.e.d rear lights, Ch/Lh lights,puddle lights,Cruise Ctrl, Ambient Interior lighting, footwell lights & it's a Quattro......
    Jul 2012
    17
    Please matey I have a road trip to turkey waiting for me and I really can't be bothered with CDs
  1. Concert HU + 6 Disc Changer - Getting Aux In
    By thejoose in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2009, 17:07
  2. Help - Looking for this front bumper urgently - Pic Inside
    By Manny_K in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2008, 15:22
  3. Aux in on Concert?
    By confusionhunter in forum In-Car Entertainment
    Last Post: 22nd October 2006, 09:12
  4. Aux in on Concert radio for PDA/MP3 player
    By synthdood in forum In-Car Entertainment
    Last Post: 11th November 2005, 16:35
  5. volume problem get any worse on concerts?
    By paul_brad in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 21:33
