Badger5AH Fabrications
    Jun 2012
    A, A
    Talking A3 upgrade - help!
    Hello there! I'm just entering my first week of Audi ownership. I have a 2011 A3 TDI SE Sportback with the basic Chorus HU. Appears there are no rear speakers! Considering a 2nd hand Symphony (via Ebay) but can I ask.... 1) Is it likely that there are speakers in the back of the car - just not connected? (2) Will Symphony II work? The II has the cassette slot - I've seen a III without this but they are £££££s! Thanks! DAVE
    Apr 2012
    N. Wales, LL22
    1,224
    there will be speakers, unless someone has removed them lol
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No there will not be speakers there, I have just had to add rear speakers/sub to an A3 that was supplied incorrectly. I bought a SUB and the two speakers from ebay for about £100 and then made my own woring loom.
    Jun 2012
    A, A
    A3 stereo upgrade
    Quote Originally Posted by s8craig View Post
    Thanks S8Craig. So, as I understand it, it doesn't matter if you have a Chorus or a Symphony HU in your vehicle - that HU only drives the front speakers. If you want 4 speakers, you need to add an amp and/or subwoofer, the amp driving the rear speakers/sub. Are wiring looms for this readily available? Assume you are going to need quite a substantial one as it has to power the amp, pick up from pre-out on HU, etc!
    Tempted to try this myself or possible entrust it to a specialist... Seems the tupperware Audi/Bose sub that fits in the back is less than popular with audiophiles so am tempted to get an Alpine or Kenwood amp and get some decent speakers in the doors. Sub isn't that important - it would only scare the dog! Dave
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Well contrary to popular belief the chorus II+ doesn't actually have outputs for the rear amp either, i had to replace the chorus with a concert to use the newly installed rear sub.
    The amp is built into the SUB, so unless your putting in a 3 way amp/SUB setup then I would stick with Audi system, you need to buy the sub for the shape of your car, normal or sportback, two speakers and all fixings to mount them into the doors etc.
    The car I worked on was a normal car, I bought all the fittings and connectors/repair wires from a dealer and then made my own wiring loom up using the repair wires and my own additional cables. Yes you will need 2.5 cable for the power, I got that from the fuse box at the front right.
    So cabling wise you need
    Screened cable 4 way to reach the radio in the front for L&R and remote
    2 wires for power, +12V to fuse box front of car right and one to ground local to SUB.
    2 wires for CAN hi & lo cables to reach the radio
    4 wires for speakers in rear L & R
    Jun 2012
    A, A
    Thanks for your help. I think I'm going for a 4x100w amp powering speakers in the 4 doors. I see that the rear connections allow you to use 4 pre-outs rather than the 2 front outputs. Was worried that if HU only throwing out 20w pc then power amp will be pushing too much into rear pair so better to drive all 4 through one amp (?) I don't aspire to an audiophile set up - just something that I like - the home hifi is where I seriously listen to my music... Dave
  1. headlight upgrade help
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2007, 12:55
  2. S3 system upgrade help please
    By trogen in forum In-Car Entertainment
    Last Post: 8th December 2006, 16:51
  3. AUDI A3 ICE UPGRADE HELP
    By Bran in forum In-Car Entertainment
    Last Post: 18th November 2006, 19:34
  4. A4 Avant sound upgrade - help/tips
    By s11eps in forum In-Car Entertainment
    Last Post: 7th May 2006, 15:23
  5. sat nav plus upgrade!! help needed urgent (please)
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 18th November 2004, 14:59
Tags for this Thread
