EM TuningVolks Autos
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By AndyMac
Thread: Aftermarket speaker recommendations for audi a3 8p sportback
    amit91987's Avatar
    Nov 2010
    South West London
    98
    Visit amit91987's Instagram Channel
    Hi,
    I have realised my rear speakers are not as loud as the front ones. I do not have a Bose set up, so I am considering changing all speakers to aftermarket ones.
    Does anyone know why the rear speakers are not loud as the front ones, by this I mean when I have passengers they cannot hear the music. I have checked all the settings via my headunit- all seems to be fine.
    Also, any recommendations for aftermarket speakers?
    Thanks in advance.
    Jun 2012
    Bristol, UK
    54
    You may want to give a budget otherwise recommendations could be between £80 and £800
    I've just installed some Focal Access A1's in the front, sound is amazing.
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
    Red ambient lighting
    amit91987's Avatar
    Nov 2010
    South West London
    98
    Probably between 150 and £250.
    19" speedlines, S3 rear, LED tail lights, Votex Spoiler, Bi- Xenons, Auto lights, Cree Led fog lights, Eibach Sportlines, Tints, Pioneer HU, Reverse Camera, Carbon fibre trims, LED interior lights
    amit91987's Avatar
    Nov 2010
    South West London
    98
    Ideally would want pioneers if they fit around that budget. However, would not mind other speakers that are of a good quality.
    Jun 2003
    World of my own
    9,813
    Are you using the stock HU or aftermarket? Really no point spending that sort of money on rear coaxials driven off the stock 2 x 20w rear amp
    Alex Turner
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    rather than upgrading speakers, adjusting the fader setting more toward rear bias and cranking up the volume would achieve a better effect than changing speakers - which would still leave forward bias anyway.
    2009 A3 SB 2.0T DSG S line
    amit91987's Avatar
    Nov 2010
    South West London
    98
    Andymac- i am using an aftermarket unit, the pioneer avh 8400BT.
    Artimus- i have tried adjusting the fader settings, but it seems my rear speakers are very quiet. Is this common for non bose setup?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    I don't think it's common on any system! output is usually pretty well balanced on all of them. are you sure you don't have an 'enhanced' output selected on the Head Unit ..i.e: Pop, Rock, Church, Wide, etc??? as this can affect the output levels in multi-channel systems.
    amit91987's Avatar
    Nov 2010
    South West London
    98
    I don't think i have selected any enchanced output. The only setting i have messed around with is the different equaliser settings, i.e. superbass, flat etc to see if this made a difference on the rear speakers, which it did not.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    In that case I'd recommend checking the polarity of the rear speaker wiring is correct on both sides.
    amit91987's Avatar
    Nov 2010
    South West London
    98
    Thanks, I will try and fiddle with the fader settings and if that does not work, I will have to get someone to check the polarity.
    Jun 2003
    World of my own
    9,813
    No it's nothing to do with settings on the HU. It's because you have twice the power going to the front speakers from the 2 x 50w internal amp in the Pioneer, but the rears are still using the feeble 2 x 20w rear amp inside the subwoofer enclosure.
    You need to rewire the rears directly to the HU which will solve the issue, then reconnect the audi rear/sub adapter to the subwoofer pre-outs on the Pioneer and jack the sub level right up. The sub will still struggle to balance with the cabin speakers but at least you will have balanced rears.
    Alex Turner
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    Is there a sub\amp in the non Bose system Andy
    Jun 2003
    World of my own
    9,813
    Yes the non Bose version has a 50w (peak) subwoofer powered by a 4 ch amp inside the tupperware enclosure with 2ch's powering the rears. The Bose version is 100w (peak) powered by the 6ch amp on the drivers side in the boot, with the other 4 channels powering the cabin speakers
    There were a few models produced with no subwoofer or rear speakers (god only knows why as it's all of £50 worth)
    Artimus likes this.
    Alex Turner
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    I'm here to learn & stand corrected. Thanks.
  1. Recommendations for Audi independent in SE London?
    By 23e Heure in forum General Automotive Chat
    Last Post: 9th May 2012, 09:13
  2. Sidelights for Audi A3 2010 Sportback
    By mucker in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2011, 15:20
  3. Advice on Aftermarket Alpine stereo for Audi A4 B7 - FM RADIO!?!
    By urbanxperience in forum In-Car Entertainment
    Last Post: 26th January 2011, 15:01
  4. Urgent: What Brake Pads Would you recommend for Audi A4 S Line Sport
    By Nza in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st November 2009, 15:33
  5. Aftermarket Headunit for Audi. - Which one?
    By Luuc in forum In-Car Entertainment
    Last Post: 13th July 2004, 09:15
