EM TuningAH Fabrications
    kolash's Avatar
    Dec 2011
    London
    44
    RNS-E Bose Coding
    Hey
    I have recently fitted a RNS-E 8PO 035 192S.
    Previously I had the concert. Now I've had it a few days I think the concert sounded better - we have swapped the bose brown wire from pin 5 to 7.
    We didn't check the volume characteristics (Adaptation 8?) as they are not listed in the on-line Ross Tech Wiki. Does anyone know the list of options? Do they affect sound quality?
    I have seen code 255 mentioned elsewhere for Bose, is this correct?
    I can't see any GALA settings available on the unit which might suggest it is already coded for Bose or it's on '0' disabled setting.
    When swapping the brown wire on my car's loom pin 7 had a grey 'k-line' wire. I assume this is redundant but we put it back in pin 5. Would this cause any problems?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The Grey wire in pin 7 is the AUX input wire, that should have been removed and moved to the 32 pin connector along with the green wire in pin 1 and the yellow wire in pin 3. There is no K-line on an A3
    kolash's Avatar
    Dec 2011
    London
    44
    Quote Originally Posted by s8craig View Post
    Thanks, would this affect the sound quality in general?
    The diagram on top of my concert was not in English so difficult to work out what the grey wire was! I guessed K-line from the RNS-E diagram but should've known K-line isn't used on the A3.
    Which pins do these wires move to on the 32pin connector? I don't use the Aux-in is it safe to leave as is until I can get round to changing it?
    Any ideas on the Bose coding?
    A3 Sportback 2.0TDI 140
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    0xx9xxx for BOSE coding on the RNS-E and 255 in adaptation channel 8
    Leave the 3 wires disconnected and taped up until later
    kolash's Avatar
    Dec 2011
    London
    44
    I currently have it coded as 0205757 so maybe that explains the quality issue. Will check adaptation 8 is on 255.
    We need to put all of this and other threads into one mega RNS-E retro-fit guide!!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    There are hundreds of guides, coding settings etc all over the forums and internet if you look, you seem to be reinventing the wheel.
  1. RNS-E Radio code questions ....
    By GavConner in forum In-Car Entertainment
    Last Post: 3rd August 2008, 11:49
  2. RNS-E BOSE / GALA setting S3 8P
    By Whiteatom in forum In-Car Entertainment
    Last Post: 9th July 2008, 23:04
  3. Audi Sat nav plus RNS-E Bose HELP !
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2008, 21:55
  4. RNS-E VAG coding question
    By jvbates in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st April 2007, 20:58
  5. BOSE Coding - Help Needed!!
    By JamS3 in forum In-Car Entertainment
    Last Post: 8th September 2006, 14:12
