Shaun Burford
Hi,
I have got a problem with a bluetooth install. A Bit of background. I have a RNSe, retrofitted by CraigB (very efficiently i might add, cheers Craig) and all has been working well. But i wanted to have bluetooth too and trying to save money found someone on ebay to fit it cheap. Bad move really.
The bluetooth all works. It pairs and i can make and receive calls. The phone book shows up so i know the car and phone are talking. But once the car goes into sleep (like overnight) when i turn it on the RNSe says your phone is not connected. Its like the bluetooth module isnt waking up. The only way to get it working again is to disconnect the bluetooth module by removing the connector and reconnect it, then hard reset RNSe. But this only works until the car sleeps and then it stops again.
The module has been swapped over and tested in another Audi and worked fine, so im sure the hardware is ok, not so confident on wiring / coding... Im beginning to think the guy didnt really understand how it all works - yet i have had it working for a bit.
Has anyone had this issue? Any ideas how to fix it? Just wished i'd spent a bit more and had craig do it with the rnse. saved me aload of hassle.... I reckon im gonna have to sort this myself as ebay man is trying to wriggle out of it.... blaming the rnse install (which was plug and play with a kufatec harness so cant see that as the prob)
Help would be very much appreciated,
Thanks,
Shaun
Thanks,
Shaun
