Badger5JMB Retrofits
    Rays18's Avatar
    East Tattoo
    Feb 2009
    N.Ireland
    41
    A4 B6 Single to Double Din conversion
    As the title really,
    Apologies in advance as it has prob been covered before but I cant find anything !!
    Well currently I have 02 A4 Saloon, it has the single din Audi Concert in it but Im wanting to change to aftermarket double din. Is it as simple as moving the heater controls unit down into the empty pocket below? Or is there much more to it
    Id imagine someone has done this before !!
    Thanks !!
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    You need,
    A double din cage from audi.
    You can move your climate controls down but you will have to cut the facia with a dremel as it's gets smaller the lower down you go many on here have done this to save money.
    You may need additional wiring harness depending on what you have fitted now kurfetec do theses.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Rays18's Avatar
    East Tattoo
    Feb 2009
    N.Ireland
    41
    Anyone done this ??
    Jul 2011
    Cornwall
    205
    Quote Originally Posted by Rays18 View Post
    Anyone done this ??
    Quite a lot of people have done this conversion, use the search tool on the top of this page and you'll find info and guides on the conversion.
  1. Single to Double Din Conversion
    By GStatus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th May 2012, 13:41
  2. Audi A6 C5 Single to Double DIN Conversion
    By flippantdj in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd March 2012, 20:09
  3. Nav+ and Bluetooth Retrofit: single-DIN to double-DIN conversion
    By jesters3 in forum In-Car Entertainment
    Last Post: 14th May 2008, 13:12
  4. Single to Double Din Conversion
    By mordz in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2007, 11:18
  5. Single DIN to double DIN conversion
    By moogie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th October 2005, 20:38
