Badger5Chris Nott
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    Will an RNS-E allow BT audio?
    Hi, I need a little audio advice and hope you guys can help.
    I have a Concert II + Bose factory fit stereo in my '09 A3, I also have the MFSW & BT Low prep w\ voice dialing. My iPhone connects to the interface automatically on ignition ..but it doesn't allow for BT Audio (A2DP). I'm considering upgrading the headunit to the RNS-E or a different make entirely, but would prefer a factory unit if the features are rich enough.
    So does the RNS-E allow BT music playback or is it limited to calling functions only, the same as my current system? Also, will my Aerial need upgrading if I go the RNS-E route?
    Thanks.
    2009 A3 SB 2.0T DSG S line
    Jan 2012
    1,837
    You can get A2DP if you get AMI and the optional bluetooth dongle
    You will need the newer 193 model RNSE for AMI though (afaik)
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    Thanks for the reply.
    Will the AMI cable plug into a Concert II headunit or is it RNS-E fit? also important, with the BT dongle will I see track\artist info & be able to select tracks\playlists via the headunit?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No and No
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    okay, thanks Craig.
  1. RNS-D audio calibration
    By scrotum in forum Satellite Navigation
    Last Post: 1st December 2010, 22:37
  2. Will this work with the RNS e?
    By EvolutionV in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 00:40
  3. RNS-D TV Tuner Audio loss
    By Ricey18 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2009, 12:52
  4. RNS-e audio outputs
    By sakkie69 in forum In-Car Entertainment
    Last Post: 15th September 2008, 19:39
  5. will RNS-E from A4 work in my 2000 Audi A6?
    By shufti in forum In-Car Entertainment
    Last Post: 19th August 2007, 15:17
