EM TuningChris Nott
Results 1 to 9 of 9
Thread: power cable
    Oct 2005
    wirral
    45
    power cable
    How have you guys got your power cable though the bulkhead in an 8L A3?
    im going to be running 2 amps so will b a fairly large cable
    Jun 2003
    World of my own
    9,813
    Re: power cable
    Yep, easiest way is via the grommet under the wiper splash guard. If you look at the passenger side in the engine bay you'll see the big plastic trunking going up to the top of the bulkhead/firewall. If you prise up the rubber you can lift up the plastic splash guard and you'll see the pollen filter and right in the front corner a good sized unused grommet. This drops down behind the glovebox straight into the footwell.
    See Deans thread for photo's
    Power cable routing
    jase0851's Avatar
    Oct 2004
    yorks
    778
    Re: power cable
    i bolted mine to the power block in the driverside footwell on my a4 ? are a3,s different ?
    Jun 2003
    World of my own
    9,813
    Re: power cable
    No, but this is not good practice as the power block is driving other hefty components in the car, so adding a current draw of anything from 30-100 amps will cause other problems. Namely fuses blowing, interference and possibly distortion on the amp as it tries to pull hefty current through the bottleneck.
    Dean_T's Avatar
    May 2004
    West Mids
    511
    Re: power cable
    here ya go;
    http://www.audi-sport.net/ubbthreads...;page=1#193876
    EDIT: doh just realised Andy linked to that [img]/ubbthreads/images/graemlins/blush.gif[/img]
    0 guage will run down the car fine and theres no issues with interior not going back, it all slots back just like it came out of the factory [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    good luck!
    jase0851's Avatar
    Oct 2004
    yorks
    778
    Re: power cable
    it seems to be working ok no fuses blown, couldnt find a way into car, i am using 0 guage aswell with an alpine mrd 301 mono amp and rockford sub it sounds excellent !
    jase0851's Avatar
    Oct 2004
    yorks
    778
    Re: power cable
    is this routing method the same on the a4 ??
    Jun 2003
    World of my own
    9,813
    Re: power cable
    What is the point of running 0 guage from the fusebox?
    No on the A4 you go through the ECU box, it drops right into the drivers footwell.
    jase0851's Avatar
    Oct 2004
    yorks
    778
    Re: power cable
    the amp is still gettin 14.4 volts and 0 guage is all i had !
