AH FabricationsChris Nott
    Feb 2012
    Aux point diy help please ? !!!
    Hi guys , Have decided to do an aux point diy on my a4 avant I have the concert stereo and have made up the aux point wiring but have struck an issue, when I hold down the cd button to select the cd changer that I'm connecting the aux wires to it says No CDC
    Does this mean I need to get it coded using vag.com or do I have to have something connected to the aux for it to recognize the ext source ?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The radio will not recognise a set of wires, it needs to be fooled into thinking it has a CDC attached.
    But how old is the car and what type of concert radio is it? single or double DIN?
    The 2007 onwards double DIN concert/symphony II+ radios have an AUX port, it just needs coding.
    Feb 2012
    It's a 2005 and has the concert 2 head unit I believe, I've had the radio coded to say it has a cd changer but still says no CDC I've connected to the cd-l and cd-r and s-gnd to the aux point, have I missed something does another pin out need o be connected to something ?
    Dec 2011
    Glasgow
    195
    Hi Alan
    What is it you are trying to fit?
    A CD changer or a line in aux connection?
    If its a cd changer then the changer doesn't use the aux in connections it uses it's own connections
    If its the aux line in your trying to install so you can plug the jack into your iPod headphone socket then it uses the 3 aux connections on the back
    Aux L
    Aux R
    Aux ground
    When you code it in there's different options to choose if present
    Cd changer
    Phone module
    Aux in
    You have to code them in to tell the head unit what options are fitted
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
  1. need a point in the right direction...
    By tezmanian devil in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2011, 19:57
  2. 3.2 jacking point
    By clem2192 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2010, 23:19
  3. From which point...
    By mdre83 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd June 2008, 22:05
  4. PIC: What is the point ..... ?
    By hop2407 in forum Jokes, Games & Humour
    Last Post: 13th August 2006, 08:22
  5. help; point to look out for
    By Toots in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2006, 12:49
