Chris NottJMB Retrofits
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,145
    Symphony to Symphony II+ Questions
    Well, I have decided to go for the Symphony II+ over the RNS-E for my 2002 A4.
    This is due to the fact I don't really use satnav - and when I do I use my phone.
    The main reason I was going to go for the RNS-E is due to the fact it plays MP3 & music can be loaded to SD cards.
    However, due to cost restraints I decided to go for the Symphony II+ as it would allow me to load 6 MP3 CDs with a slight increase in sound quality.
    It took me two weeks to track one down, must have sent in excess of 50 emails and around 20 calls to breakers.
    Finally found one yesterday from a 2008 A4 on ebay USA which I snapped up - shipping was $47 and I got the unit for $150 which I was pretty happy with.
    However, I have a few questions;
    Obviously being a full canbus unit, the Symphony II+ requires a quadlock connector, will the one for the RNS-E work?
    I have found the following, so taking it that it probably will work?:
    KUFATEC GmbH & Co. KG - Audi Bundle Adapter Radio- Navigationseinheit BNS 5.0, Concert 3 35713
    2nd question is coding. With the unit being from America, I am taking it the coding will be slightly different.
    I have found the following, but I am unsure as to how it is done (I have access to a genuine vag-com cable & software)
    Audi Radio Generation II Plus - Ross-Tech Wiki
    Thanks!
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It will require a quadlock adaptor and coding as the american FM frequencies are different from ours. Using VCDS is pretty easy.
    27,014
    Only issue may arise, is radio reception given newer radio's use different antenna system to the rns-e & B6 era afaik, craig should confirm aswell, think was about mid 06 they changed things around, I know on the 8P was mid 06/07 onwards, real pita but thats vag, every penny counts
  1. symphony 2 aux in questions
    By dvalve1 in forum In-Car Entertainment
    Last Post: 23rd February 2012, 23:49
  2. HELP!! Symphony II to Symphony II+ Strange Radio Problem
    By BennyB0Y in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2009, 15:46
  3. Audi A3 (2004) Symphony II to Symphony II+
    By xandertarr in forum In-Car Entertainment
    Last Post: 23rd October 2008, 09:27
  4. Symphony to Symphony 2 upgrade problems
    By shollis in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2007, 16:50
  5. Symphony questions
    By Freethy in forum In-Car Entertainment
    Last Post: 22nd January 2007, 14:27
