Monster MotorsportChris Nott
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    S3 2001 Bose front speakers not working - replacements?
    Gentlemen
    My newly acquired S3 only has working rear speakers. Its a bose system
    Is this common?
    What is the speaker set up for the car? 4 or 5" mid and a tweeter up front? Not sure on rear
    Can anyone advise what is best to replace them with? and is it an arse of a job with interior trim panels?
    many thanks
    Dave
    Jun 2003
    World of my own
    9,813
    All speakers in the Bose system are 4" on the 8L A3. Tweeters are 1".
    You really need to replace like for like as they run at 1 ohm impedance, so even low impedance replacements will only deliver less than half the power from the Bose amp.
    If you have no sound at all from the front then I doubt it is a speaker problem as the tweeters should still work, more likely the Bose amp.
    Instructions are here for removing the door cards:
    http://freepdfhosting.com/7f903e1adb.pdf
    Alex Turner
  1. Replies: 4
    Last Post: 9th March 2012, 20:48
  2. Bose Sat Nav System - Rear Speakers not Working
    By biyitch in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th February 2010, 23:39
  3. Bose rear shelf speakers and sub stopped working?
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th May 2009, 12:27
  4. Bose front speakers
    By HODD in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2009, 09:15
  5. Replacing front / rear BOSE speakers in new A3
    By cheechy in forum In-Car Entertainment
    Last Post: 31st August 2004, 18:21
