Volks AutosAH Fabrications
Results 1 to 28 of 28
    Mar 2012
    29
    Audi Concert II to RNS-E & Bluetooth
    As above, I currently have the Concert II stereo in my A3. It also has factory fitted bluetooth installed, which has been working fine in terms of reiceving calls etc. Although I don't have the ability to look up contacts, which i'm sure if my headunit is supposed or not may be the case to do?
    My question is if I upgrade to the RNS-E, will the factory fitted bluetooth continue to work seamlessly or is my current bluetooth set-up only functional with my Concert II headunit?
    Many thanks in advance for the help.
    Apr 2012
    Cambs, UK
    66
    I'm certainly no expert matty but I think the bluetooth is seperate from the headunit so should be fine.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,607
    Will work fine with RNS-E.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    27,027
    The rns will significantly improve the BT interaction & even better with an mfsw
    Dec 2011
    Glasgow
    194
    Hi sorry for hijacking a post but I saw you have a concert 2 stereo with oem Bluetooth.
    I didnt think that you could use the Bluetooth module with that head unit
    Just asking if you can because I have got the Audi Bluetooth module cheap a while ago but never installed it because I thought it required the rnse to work
    So just wanting to confirm can you use and connect the Bluetooth module to a concert double din head unit
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    Jan 2012
    1,837
    Quote Originally Posted by Gazthesparky View Post
    Yes 100%, just buy the relevant plug and play cabling and mic from ebay and code it to the car and job done
    Cabling - BT KABELSATZ OEM ► RNS-E Concert ► 8P1862335 8P0862335 | eBay
    Mic - AUDI RNS-E ORIGINAL BLUETOOTH VOICE CONTROL SDS MICROPHONE MIC - A3 A4 A6 TT R8 | eBay
    Dec 2011
    Glasgow
    194
    Brilliant you learn somthing new everyday lol I will bave to check elsa out and get the loom made up that's another job added to my list
    In the future I will be purchasing an rnse but untill then I can use the bluetooth
    To what extent can you use the Bluetooth I have a multifunction steering wheel and dis does it just connect to your phone and the cut the stereo when you receive a call ?
    Mods
    Full VCDs
    Jan 2012
    1,837
    Yep, press the mode button for your phonebook then scroll using the scroll wheel on the left hand side ..
    You can also press the voice button on the steering wheel for voice dialing but I'm not sure what else you can do as mine speaks to me in German and I can't get it changed due to modified software
    Apr 2012
    Cambs, UK
    66
    Mine speaks in english and I still struggle to get it to do anything!
    'Dial home', "sorry?", 'Dial home' "Do you want to delete home", 'no!!!' is about how it normally goes!
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    Haha, my voice recognition isn't too bad actually. I use the following to dial a number:
    Me: "Select name"
    Audrey: "Name please"
    Me: "Beth"
    <Repeats my recording of 'Beth'>
    Me: "Dial"
    Audrey: "Number is being dialled"
    My biggest problem is storing a voicetag...
    Me: "Store"
    Audrey: "Star"
    Me: "Delete. Store"
    Audrey: "Star"
    Me: "Delete. Store"
    Audrey: "Star"
    Me: "Stupid slut"
    Audrey: "Pardon?"
    Dec 2011
    Glasgow
    194
    Just another question regarding the Bluetooth and the speech dialling is the SDS part of it a different module or is it done via the BT module ? I've got a MFSW with the mode buttons and speech button
    Also I have a module that ends in a D but I see there are others that end in a E what's the differnces ? And where can I find out the differences between the modules ? Is there a list somewhere ?
    Mods
    Full VCDs
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    Voice commands are from the Bluetooth unit itself and SDS is part of the RNS-E Sat Nav system.
    No difference between D & E - both support basic functionality, which means they aren't compatible with the RNS-E Sat Nav. Bluetooth would still work fine if you retrofitted an RNS-E but you wouldn't be able to dial or view phonebook from RNS-E etc.
    Dec 2011
    Glasgow
    194
    Ok
    That's brilliant so there's no difference between them
    So does that mean then when I install an rnse in the future I will have to replace the BT module if so which module will I need so that the BT works with the Rnse ?
    Mods
    Full VCDs
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    You don't need to install a different bluetooth module, only if you want to unlock the features in the RNS-E which includes the dial, phonebook, received calls and dialled calls.
    You can choose any Bluetooth revision except from A, D, E and ones without a suffix. I'd also stay away from rev K as this one has known firmware issues.
    Dec 2011
    Glasgow
    194
    Cheers jb0o
    Quote Originally Posted by jb0o View Post
    Can I just check that ive got this correctly my D module will work with the RNSE and my current concert HU and in the future when i retrofit the RNSE it will work but it won't have all the functions you stated If I want all the functions then I need to upgrade the BT
    Unit to any number APART from A,D,E and K ?
    Mods
    Full VCDs
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    Yup thats correct.
    rev K will be fully compatable with the RNS-E however a lot of these were replaced under warranty due to a dodgy firware, so best keep away from one of those unless it's dirt cheap.
    I've got rev 'H' in my A3 and works perfectly with the RNS-E.
    27,027
    Quote Originally Posted by a6_chris View Post
    Cant see why you cant change this tbh.
    Jan 2012
    1,837
    Read my thread on here Nigel, I found out its been flashed with new software from vcds.
    8P A3 OEM Bluetooth 8P0 862 335 AA - Request Out Of Range
    Dec 2011
    Glasgow
    194
    Hi can I just double check will a BT unit ending in a S work in a A4 B7
    It states it is a Europe module
    Just want to check cheers
    Mods
    Full VCDs
    27,027
    Yes
    Dec 2011
    Glasgow
    194
    Cheers NHN
    Mods
    Full VCDs
    Dec 2008
    25
    Just a quick bluetooth question.
    On a Concert II+/Symphony II+, without MFSW, will the bluetooth module work?
    Can it be controlled only by phone, or is it completely unusable?
    Thanks.
    Jan 2012
    1,837
    Depends on the phone
    Dec 2008
    25
    What do you mean? what is the phone supposed to have, besides bluetooth?
    I was reffering to making and receiving calls just using the phone, and then talking through the car kit. Any phone can make and receive calls..please be more specific.
    Thanks..
    Jan 2012
    1,837
    Well on some phones when a Bluetooth connection is established the phone locks out certain functions.
    I asked because on an iPhone the software still allows you to dial from the phone but still keep the Bluetooth connection enabled.
    Dec 2008
    25
    Ok, i get it now. I was going to use an iphone, so i think it's ok.
    I remember i connected a lot of BT accesories, like BT receiver, BT ear piece, on a couple of phones and they all worked just like they usually do, that's why it sounded weird to me.
    I have a '04 A3 and a three spoke steering wheel, so no MFSW is available, there is only a 4-spoke ugly MFSW which i'm not going to use. RNS-E remains the only option to control the BT module, but that RNS-E is too expensive for me, so for a while i'll stick to controlling it though the phone.
  28. #27
    Jan 2012
    1,837
    No problem - my post was rushed but glas you understood it.
    My work phone a Samsung something or other locks out the phone when connected to the car so thats why I was wondering which phone you had but the iPhone works as normal when connected so you should be fine.
    You will need to answer the phone from the handset though but it should divert the audio to the bluetooth automatically.
  29. #28
    kolash's Avatar
    Dec 2011
    London
    44
    Quote Originally Posted by mattyg123 View Post
    Not sure if you got round to this but, I have just done this same upgrade and all works very well. The concert does not display phone contact info but it should be visible on the DIS in the instrument cluster.
    I agree the phone works fantastically through the RNS-E, you can access all your dialled/missed/received call lists as well as the phone book.
    You need VCDS to recode the phone module and RNS-E when installing to ensure all functionality works.
  1. Audi Concert 3 III & 2007 RNS-E DVD Maps
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2007, 09:43
  2. RNS-E & Bluetooth
    By Anito in forum In-Car Entertainment
    Last Post: 5th December 2006, 13:03
  3. Concert II to RNS-E & Bluetooth conversion
    By s8craig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2006, 20:18
  4. Audi S3 RNS-E & bluetooth installation
    By s8craig in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2006, 02:12
  5. Audi S3 RNS-E & bluetooth installation
    By s8craig in forum In-Car Entertainment
    Last Post: 23rd July 2006, 17:09
