Chris NottSky Insurance
    SamA3's Avatar
    Nov 2011
    71
    Yes Another HELP - I need a new headunit
    Okay so basically title says it all I want to install a new headunit to my A3 I have a concert 2 stereo but I also have a sub as standard in the boot. I have read many times this needs some special adapter although I have no clue what. Basically if I go to halfrauds tomorrow what lead adapters etc do I need to get this headunit working in my car.
    Headunit: Halfords | Pioneer DEH-4400BT - CD Tuner with iPod/iPhone Control
    Please bare in mind I will probs go to halfrauds for all the kit so if possible please make sure it's something they sell.
    Jun 2003
    World of my own
    9,813
    If you have a Concert II (single DIN) then you have the ISO wiring in your A3 so you need the PC9-410 RCA input adapter
    You will also need a fascia adapter and ISO power antenna adapter for the aerial.
    There is no switched live feed on your A3 so you will have to connect the red switched live to the permanent live and turn the HU on/off manually or buy a CANBUS emulator (£60) or wire in an ignition switched feed from the fusebox
    Alex Turner
    SamA3's Avatar
    Nov 2011
    71
    Okay I'll just turn off manually I can sacrifice doing that every time but I'm confused what you mean by all the stuff you wrote haha I'm new to electronics and iCE
    Dec 2011
    Basingstoke
    84
    why do you want a new head unit, what's wrong with the concert 2?
  1. A3 8p Headunit
    By Brad. in forum In-Car Entertainment
    Last Post: 30th July 2012, 16:51
  2. Got HEADUNIT removal keys... But can't remove Headunit???
    By kevin00 in forum In-Car Entertainment
    Last Post: 14th May 2011, 09:53
  3. New headunit
    By TurboRoss in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2010, 08:29
  4. Help With new headunit ?????
    By Mike071288 in forum In-Car Entertainment
    Last Post: 17th May 2009, 10:42
  5. New Headunit?
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2009, 17:26
