AH FabricationsEM Tuning
    a3sline_nottingham's Avatar
    Mar 2012
    64
    Bury 9060 music lead
    Hey folks
    Just installed a bury 9060 music in my car and the audio only Plays through the front speakers. I'm pretty sure it's because I have an amped read system.
    Can anyone provide me with a simple ISO harness to allow it to work with all 4 speakers
    And also will it be plug and play. Just unplugs the ISO cables and plug the new lead in, then hook it up to the bury?
    Mar 2012
    64
    ive seen a lead - SOT-1002HB which is for rear amplified stereos
    Buy and install Parrot Car kit with our SOT 1000 Leads for amplified Vehicles
    and i have the following installed in my car
    http://www.bury.com/cms/fileadmin/do..._Manual_EN.pdf
    My assumption is that the kit will work with Bury and not just Parrot - Could someone see if i could plug and play this in my A3
    Jun 2003
    World of my own
    9,813
    You really need to buy a proper AUX in adapter if you want to use it for music then it will actually play through the HU rather than from the feeble output on the car kit.
    Alex Turner
  1. CONNECTING IPHONE USING BURY INCAR.....WILL IT PLAY MUSIC THROUGH IT???
    By codrock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2012, 00:36
  2. Installing Bury cc9060 Music Bluetooth
    By northtim in forum In-Car Entertainment
    Last Post: 11th October 2011, 20:05
  3. Audi Music Interface Lead
    By Wizza in forum Parts Requests
    Last Post: 4th June 2011, 20:40
  4. Can you 'upgrade' the micro can lead to a hex can lead
    By pns2007 in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th September 2009, 19:40
