Monster MotorsportVolks Autos
    Jul 2007
    130
    Symphony VCDS Code Help needed
    Have just bought a 2nd hand Symphony to replace the Concert unit in my 2008 S3 Sportback (Bose sound system).
    Installed OK and is running fine..much prefer having the 6 CD changer capability.
    But the External Aux -In does not work and I think that there is a VCDS code setting that can be changed to activate it.
    My local car-audio specialists have got a VCDS that they can plug in , but they don't know that code sttings needed.
    Can anyone help please?
    many thanks
    S3 Sportback DSG in Sprint Blue with mag ride, interior lights, Bose, parking sensors.
    and...
    99 TT Roadster
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    0?00000 add +1 to ?
    0?x0xxx: Options 3
    +1 = Analog Input (AUX)
    +2 = Multifunction Steering Wheel
    +4 = Telephone
    27,010
    TBH if they have vcds, then as soon as they login to the module, eg head unit 56 it will popup a window with the codings available for that module & they calculate it based on whats fitted to the car, similar to what craig has show you already, now of course depends on the version they have & if its genuine as to if it has the latest data to show you codings for, only 1 way to find out.
    Jul 2007
    130
    Thanks for your advice and suggestions...will print out and take it down to the audio boys.
    Jo
    and...
    99 TT Roadster
  1. VCDS: Re-code Invalid
    By IceHanger in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th March 2012, 16:23
  2. vcds fault code
    By lee58uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2012, 15:00
  3. Symphony II+ Bose equalizer settings via VCDS
    By Jameze in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2011, 13:50
  4. VCDS Security code?
    By esxb in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th May 2011, 11:16
  5. fault code on VCDS
    By kgates in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2008, 13:34
