EM TuningBadger5
    11
    Symphony stereo cutting off and on again on CD and radio
    Today out of the blue my stereo started to momentarily cut off then back on again. I was listening to CD so switched to radio but was doing the same thing. Innitially I thought loose wire as the screen goes blank then lights up with "BOSE" and resumes playing, however, it still kept doing this when I parked at work. Has anyone experienced similar? its a 2002 A3.
    27,094
    Sounds like a momentary power disconnection to me if Bose is coming up as this is what it does when turned on, I would remove radio & check the rear connectors 1st.
    Apr 2012
    Oxfordshire
    I have just experienced the exact same symptoms from today. Would be really interested in knowing what they main fault could be. I will check the power cables at the back of the stereo. Is it possible that a short circuit is occurring which momentarily overloads or puts the stereo into a protective mode? Any advice would be much appreciated.
  1. Symphony Radio CD changer
    By whispering john in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2010, 15:49
  2. HELP!! Symphony II to Symphony II+ Strange Radio Problem
    By BennyB0Y in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2009, 15:46
  3. Symphony radio code
    By Mini-mad-matt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th February 2008, 20:15
  4. Symphony II+ Radio vs CD volume
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2007, 14:00
