EM TuningVolks Autos
Like Tree1Likes
  • 1 Post By AndyMac
Thread: Concert II replacement please help
    Apr 2012
    6
    ive tried using the search function but im even more confused, i have a concert II headunit that decided to die on me, im purchased a replacement aftermarket headunit and an ISO lead that i thought would be the correct one (autoleads PC9-401).
    This evening ive got to fit my new head unit and the ISO does not fit
    how do i find the correct ISO lead and how would i know if i have a Bose unit because as far as i was aware i thought i had a standard Concert II
    you help/advice is greatly appreciated
    Apr 2012
    6
    bump
    Jun 2003
    World of my own
    9,813
    Those are the standard ISO leads and you don't have Bose (as you clearly show a brown front speaker harness, which Bose doesn't have)
    The 401 isn't the right adapter, but should still work. You should be using the 404 version.
    On the 404 the RCA's plug into the rear RCA's on the new HU, blue flying lead connects to the power antenna lead on the HU. Power connector plugs into power connector and front speaker connector plugs into the speaker connector on the HU.
    Concert II is a CANBUS HU so you won't have a switched power feed on the power connector on the Audi loom, so you will need to pair the switched feed to the permanent feed and turn the HU on/off manually or you can wire in a switched feed from the fusebox, fuse labelled Radio S-Kont
    emeritus likes this.
    Alex Turner
    Apr 2012
    6
    Thanks for your reply ive now got the PC9-404, i'll give it a go see how i get on
    Apr 2012
    6
    well hone to halfords i've picked up an autoleads pack PC9-404/PC9-410 as this was all they had, is this still ok?
    Halfords | Autoleads PC9-404/PC9-410 - Audi ISO Lead/Harness Adaptor
  1. Concert replacement with Concert
    By Jumpy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th February 2012, 18:08
  2. Concert replacement with Concert
    Last Post: 5th February 2012, 15:07
  3. concert stereo replacement
    By egesford in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2011, 18:58
  4. A3 Concert Replacement
    By papster_cfc in forum In-Car Entertainment
    Last Post: 9th August 2009, 17:51
  5. Concert II Replacement / Alternative
    By Audi-Bob in forum In-Car Entertainment
    Last Post: 26th May 2008, 22:18
