Volks AutosChris Nott
    Mar 2012
    6
    Help!! Symphony unit will not budge
    I am trying to remove my symphony radio to fit a Parrot MKi9200 unit but can't seem to get the unit out.
    I have inserted the 4 release keys but I think one corner is not unlocking.
    Has anyone else had this problem? or even better does anyone know of a way to remove the unit without destroying it completely?
    Thanks in advance.
    Pete
    Jun 2003
    World of my own
    9,813
    Firstly you need to remove the glovebox so you can push the unit out from behind
    Secondly the removal keys are inserted with the angled sides facing inwards (facing each other)
    Thirdly do not pull on the actual keys themselves otherwise the spring clips can get wedged
    Alex Turner
    26,777
    Sometimes I find, if you very very carefully push the key to the side thats wedged so it pushes the spring clips more inwards, it may give it enough leverage to pull/push that corner out, but do take extreme care & follow what Andy has kindly advised as it could be a real pita to remove if you damage the fixings.
    Rob2k68's Avatar
    Feb 2012
    109
    It probably doesn't help much now but I have found the Audi genuine keys to work much better than ones from auction sites !
    If the key is not jammed and they're close by it might be worth a trip to Audi to ask to lend a key.
    Mar 2012
    6
    Thanks for all the advice guys. I am going to have a shot at the weekend.
    Thanks again.
    Pete
  1. Anyone fitted a symphony unit in s3 ??
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2011, 15:25
  2. Sump plug won't budge
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2010, 21:42
  3. Quality of the Symphony head unit?
    By PVO_Dave in forum In-Car Entertainment
    Last Post: 12th July 2007, 18:31
  4. A4 Symphony head unit
    By jiffi77 in forum In-Car Entertainment
    Last Post: 6th October 2005, 14:32
  5. What about Symphony 1 head unit??
    By imported_ianimms in forum In-Car Entertainment
    Last Post: 5th September 2004, 00:44
