Chris NottMonster Motorsport
    sinic's Avatar
    Audi WAudi
    Jan 2011
    256
    Re Soldering Bose amp on '04 Tdi Sport
    Can anyone point me to a guide to re solder the bose amp on my tdi sport?
    I have crackly rear tweeters when cold so assume I have the dry solder connections on my amp??
    I'm not afraid to solder and want to do the job asap
    Jun 2003
    World of my own
    9,813
    If it's just the tweeters then it won't be the amp as the tweeters run off the same feed as the woofers
    Alex Turner
    sinic's Avatar
    Audi WAudi
    Jan 2011
    256
    I think its just the tweeters but not 100% sure, sounds like the tweeter coming in and out when I'm driving along....it's just on the drivers side behind me in the rear right door....
    Any suggestions?
    When it's all warmed up its less intermittent, same as if I whack up the volume it then kicks in.....
    Jun 2003
    World of my own
    9,813
    More likely it's a dirty door connector if whacking up the power cures it, common problem on the B6, you need to remove the rubber boot and clean up the plug.
    Alex Turner
  1. Will Bose speakers & bassbox fit into my none BOSE standard head unit?????
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2012, 21:17
  2. Replies: 0
    Last Post: 11th January 2012, 14:50
  3. 2.0 tdi Sport - Eibach Pro, Sportline or H&R
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2010, 20:01
  4. Immobiliser soldering
    By A4NA18 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2007, 12:41
