Results 1 to 15 of 15
    Aug 2011
    43
    Non-Bose B7 A4 (RNS-E) quality?
    Hey folks, I jut swapped my S3 (8P) with RNS-E and Bose, for an A4 (B7) with RNS-E and non-Bose. I connect my iPod through a Dension GW100 and this seems to just be a straight swap between the cars. Dension quote the same part-no in their compatibility lists, but, I'm sure something isn't quite right, the sound seems like it's missing all the mid-range and the bass is lacking punch.
    Is this normal for what I've got?
    Am I likely to need to get a different harness?
    If I was going to upgrade to improve the situation, what way would be best?
    The seller advertised the car as having a Harmon Kardon system, but all I could find was a "Harmon" sticker on the amp I found in the boot. Can anyone shed any light on what this is all about??
    Thanks all!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No differences between BOSE and non BOSE dension harnesses for RNS-E, basically all the wires except for CD changer are pass through.
    But I would say you have come from a very small compact space with BOSE to a large cavenous space without so I would expect you to notice a drop in sound quality.
    Aug 2011
    43
    Craig, what do you think is the best way forward?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Well you could go aftermarket for speakers / amps, but I have no experience of them so I cannot advise on a good solution.
    Or maybe upgrade to BOSE, but again, can be time consuming and expensive, new speakers, amps, (possibly extra speakers) rewiring front to back for line level feeds and speakers.
    Jun 2003
    World of my own
    9,813
    Harman is the stock system on the B6/B7. Are you saying the drop in quality is only when you use the iPOD? Or are you commenting on the overall difference between the Bose system in the 8P and the non Bose in the B7, which will be dramatic with or without the iPOD?
    Alex Turner
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Mrs B,s cab IMHO with no Bose sounds better than my S3 with Bose.
    Bose is mega tinny and I never liked the house stuff when I bought some and lobbed it all out for monitor audio.
    Aug 2011
    43
    Thanks Craig, if i go the bose route, i'll likely be asking a whole bunch of additional questions! I really would prefer as OEM as possible
    I was going to compare between SD card MP3's and the iPod, then I remembered that while the Dension is plugged in, all sound to the speakers is running through the Dension harness. I know craig has said there is no difference between Bose and non-Bose and that it's just pass-through, (which explains why it "worked" when I plugged it in) but I'm tempted to take the harness out and try all OEM from the SD card, compared to SD card running through Dension harness.
    Aug 2011
    43
    Blackie, that's strange, I love the way my S3 sounds. I guess it's different strokes for different folks! I'm no audiophile, so my taste is probably not one others would want, I just know my A4 sounds really weird, like something's missing!!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    it's a simple test to do, but unless the harness is faulty in some way then it should be no different with or without the Dension
    Aug 2011
    43
    ..true that, it might just be the difference between the two chassis as you first pointed out Craig, sound is one of those things that's really subjective I guess. I just found out that a colleague of mine also has an A4 avant (B6) without Bose, I'll see how the two compare, perhaps I'm just expecting too much of the B7!! - Thanks for your responses all, appreciated.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Just checked the differences between non BOSE and BOSE in an Avant, hoping you have got an Avant. The only extra speaker is the center dash speaker. So it should not be too difficult to swap all the speakers to BOSE and add the center speaker and then rewire the front speakers to the amp in the boot and run line level wires to the rear as well for the front speakers. Along with a mic in the roof for the audio pilot.
    Probably about a days work to do it, but some custom wiring required.
    Here's a complete BOSE system I found on ebay inc cables
    eBay: Neue und gebrauchte Elektronikartikel, Autos, Kleidung, Sammlerst�cke, Sportartikel und mehr � alles zu g�nstigen Preisen
    I had an S8 (2001) with BOSE and the sound was superb, I swapped to an RS6 (2004) with BOSE and the sound was really washed out, not tight at all compared to the S8.
    Aug 2011
    43
    Cheers Craig! Yeah I've got an avant, but seems to have a centre speaker?? On top of the dash, near the windscreen air vents.
    It doesn't look like an expensive thing to retrofit, which is good, given the new renovation project and baby due in June!
    If I'm taking the door cards off, I might plan to install some LED's (like the lights package, puddle lights/grab handles etc, in red)
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It may have the grill, but does any sound come out? AFAIK there is no center speaker on the non BOSE system.
    Aug 2011
    43
    Will have a proper listen in the morning, but pretty sure it was making noise... Or perhaps I just hoped it was!! Will write back!
    Aug 2011
    43
    Nope, I wasn't dreaming, it does work. Going to do shocks and springs as first mod, so will re-open this book now I know it's not mega expense.
  1. Poor sound quality RNS-D
    By Louis Cronin in forum In-Car Entertainment
    Last Post: 8th May 2010, 13:46
  2. RNS-E Sound quality
    By rowdyboy in forum In-Car Entertainment
    Last Post: 27th April 2009, 19:36
  3. Bose Sound Quality
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2007, 13:39
  4. Concert Bose sound quality issues
    By JayMark in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th August 2005, 07:31
  5. BOSE Quality??!!
    By simondavidr in forum In-Car Entertainment
    Last Post: 2nd May 2004, 22:14
