Badger5Chris Nott
Results 1 to 11 of 11
    Sep 2005
    NY
    43
    Symphony in A4 s-line
    hi all,
    i have the 6disc in dash head unit fitted to my A4 s-line. overall i find the sound system good.
    is it possible to wire a sub/amp upto this type of head unit?
    anybody done it? worth the work?
    cheers
    Jun 2003
    World of my own
    9,813
    Re: Symphony in A4 s-line
    Yes & yes.
    Definately a good move and not only give you much needed bass, but will improve the overall sound as well.
    The rear speakers are driven by a tiny amp so you can pick up the rear pre-outs & remote on from this amp to feed the sub amp. So all you need to do is run power to the boot.
    Sep 2005
    NY
    43
    where is the amp located?
    Jun 2003
    World of my own
    9,813
    Depends what year, but usually it is bolted to the underside of the rear left speaker in the rear deck.
    Sep 2005
    NY
    43
    my car is a 2004 model. ill have a look about, thanks mate
    Nov 2004
    10
    Hi,
    If your car is a saloon the amp is behind the right hand side boot pannel on a plate above the wheel arch.
    Hope that helps,
    Phil
    Sep 2005
    NY
    43
    thanks all, just one last question. in my last car my head unit had an independent control for the sub volume etc.
    how would i control it thru the symphony head unit? or how else can you control it?
    sorry if its a daft question
    Jun 2003
    World of my own
    9,813
    There's no independent sub control on any Audi HU. You either just use the Bass control, fade to rear or disconnect the rear amp and use the fader to control the sub on its own. If you're really keen you could reconnect the rear amp to the front pre-outs, so you'd lose the front rear fade option but have independent control of the sub.
    The only other way (apart from fitting a decent HU) is wiring up a pot to the sub amp pre-outs and mounting it on the dash (not nice) but this would only cut the level going to the amp.
    I doubt the feeble Symphony pre-outs would like it too much either
    Sep 2005
    NY
    43
    do u think a sub will sound and add ok bass with the existing head unit or do i really need a new head unit with sub control?
    Jun 2003
    World of my own
    9,813
    It'll sound fine, you just need to spend a bit of time getting the gain set correctly, try it out with a really bassy CD to ensure you have enough control over it using just the Bass setting so that it's not too loud, but with a tinny track you have enough sub gain so that it sounds good without having to jack up the Bass to max.
    Sep 2005
    NY
    43
    thanks for the advice mate, much appreciated
