DPMAMD Technik
Results 1 to 8 of 8
    Feb 2012
    Post Thanks / Like
    Is the BOSE amplifier adjustable?
    Hi,
    I've just installed an aftermarket headunit to my 2002 S3.
    It had the fully amplified BOSE system which I've bypassed by getting a converter from the back of my stereo so the speakers simply run directly from the ISO connectors which seems to work fine, but even when the volume on the stereo is on '1', it's fairly loud.
    The sound will still have to come through the factory fitted BOSE amplifier but is there any way of adjusting the output level on it?
    Also, where is it?
    Thanks in advance,
    James.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    The amp is in the drivers side cubbyhole in the boot behind the rear light cluster. You can't adjust the gain on it. I would question the adapter you've used, sounds like you have connected the speaker outputs directly to the amplifer input stage - not a good idea. You need a hi-lo converter (line out converter) if that is the way you want to connect it up, which takes the high level speaker outputs from the new HU and brings them back down to low level pre-outs which then feed the Bose amp.
    Part no. PC9-408
    Alex Turner
    Feb 2012
    Post Thanks / Like
    Thanks for your quick reply,
    The part you mentioned - PC9-408 is the part I've used to attach the HU to the car.
    I did originally connect it directly out of the RCA low input converters but that created a horrible "pop" whenever I changed channels on the stereo.
    If the volume on the new stereo had a '1/2' volume setting that would be ideal! Volume setting number 1 is just a little too loud to have a conversation in the car without having to raise your voice slightly.
    Hardly a real problem granted but enough to annoy me slightly.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    There should be an adjustment on the PC9-408 which allows you to reduce the gain fed to the Bose amp
    Alex Turner
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    114
    Post Thanks / Like
    Hi Andy, I'm looking to either replace my headunit or find a way to add MP3 to it. I've got the full bose Concert 1 system factory fitted to my A4 Avant but worried changing the headunit is going to cause more issues than its worth. Hoping you can point me in the right direction?
    thanks,
    Ash
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Yes you can get a simple Connects2 adapter that provides mp3 input via the cd changer port
    Alex Turner
    adamroutley's Avatar
    Sep 2011
    Wolverhampton
    37
    Post Thanks / Like
    how do you get to the amp mentioned?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Depends what car you have?
    8L & 8P it is on the drivers side behind the boot trim, you need to remove the boot lip trim and then the rear O/S boot panel to get to the amp.
    Alex Turner
  1. B5 bose amplifier in a B6?
    By marcuswomersley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2012, 22:46
  2. Rear drivers cubby hole - Bose Amplifier
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2010, 03:52
  3. Which member was looking for a original bose amplifier for their s3?
    By sulaiman in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2010, 10:02
  4. FM/TV amplifier
    By sherry in forum In-Car Entertainment
    Last Post: 30th April 2009, 10:32
  5. Bose Amplifier removal
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 19:50
