JMB RetrofitsBadger5
    synthdood's Avatar
    Oct 2004
    Amsterdam, Netherlands
    285
    Aux in on Concert radio for PDA/MP3 player
    I have just discovered that my new PDA (Fujitsu Siemens PocketLoox 720) has a line out on the cradle plug. This is opening up some great possibilities to use it as an in-car MP3 player as well as for SatNav [img]/ubbthreads/images/graemlins/laugh.gif[/img].
    I'm now looking into getting an active Brodit cradle for the PDA and modify the plug/cable myself so that it also carries the audio signal. The only problem is getting the signal into the Audi radio. I know that the CD changer inputs can be used for this and I'm sure that finding the line-in pins on the radio is simple enough, but what do I need to do to fool the Concert radio/cd into thinking there is a CD changer installed? The usual boxes that you can buy to create a aux input on Audi radios are too expensive to my taste. I'm quite good with electronics, so unless it is going to require programmable microcontrollers, I'm sure I can make something myself. All I need to know is which pin requires what kind of signal so that the radio thinks a CD changer is connected.
    Jun 2003
    World of my own
    9,813
    Re: Aux in on Concert radio for PDA/MP3 player
    It needs dummy data on the Data In line on the back of the HU, the pin outs are detailed on the top of the HU
    imported_G4JSG
    [ QUOTE ]
    [/ QUOTE ]
    Could you please explain what to do as I am looking for this very same solution. My concert radio/CD also has the glove box 6 disk changer which I will be removing if I can get the MP3 player connection working, so I could use the wiring harness for the solution I gues????
    Any help will be really appreciated.
    John
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    This might help
    Aux input
    or this
    Aux input 2
