DPMForge Motorsport
    Oct 2008
    Post Thanks / Like
    Upgrade BNS 5.0 / RNS-Low with RNS-E
    Hi, I've been considering upgrading the BNS 5.0 head unit in my Audi A4 B7 with an RNS-E unit. The current system has a 6Disk CD Multichanger in the glove and factory fit bluetooth handsfree as well as a phone prep in the armrest.
    I was wondering whether:-
    - Is the Bluetooth built into the BNS unit or is it an extra module? Is this plug & play with the RNS-E if so?
    - Are the multichanger & GPS aerial also plug and play with the RNS-E?
    - Once i've upgraded the unit is it simply a matter of using VCDS to configure it? I've got a generic cable and the $99 version of VCDS which can currently 'see' the BNS unit. Will this be good enough to finish the job off?
    Any help much appreciated.
    Mark
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    Bluetooth is a seperate unit, so no changes required there between BNS and RNS-E
    No it's not plug and play, the K-line wire will have to be moved along with the BOSE wire, but I don't think you have BOSE.
    Yes everything else will work as before.
    You may get away with a cheapo VCDS cable if it allows coding over K-line
    My Retrofit Website
    http://www.tclsatnav.com
  4. Thanks markhaines thanked for this post
  5. #3
    Nov 2011
    SE London/Kent
    29
    Post Thanks / Like
    Mark,
    I found this very helpful when doing mine.
    Audi B7 S4 DIY: Symphony II+ to RNS-E Installation
    Cheers,
    Andy
  6. Thanks markhaines thanked for this post
  7. #4
    Oct 2008
    Post Thanks / Like
    Thanks for the replies. I do have Bose, forgot to mention this. I'll read round moving the wires.
    Thanks!
  1. RNS LOW into B7 A4 - Advice sought please
    By Custardsucker in forum Satellite Navigation
    Last Post: 10th August 2011, 18:47
  2. RNS-D to RNS-E upgrade, old stuff I know but help needed in Technophobe speak please
    By Bluevane in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 09:41
  3. Stereo Choice?? BNS OE RNS-E
    By keviny997p in forum General Automotive Chat
    Last Post: 26th September 2009, 12:33
  4. RNS-LOW coding help needed.
    By s8craig in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th April 2007, 16:35
  5. S4 Concert/BNS to RNS-E conversion
    By imported_craigyjp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2006, 23:46
Tags for this Thread
