Backdraft MotorsportDNA Tuning
    Dec 2011
    Nottingham
    65
    Post Thanks / Like
    Sub And Amp Wiring Issue.
    Currently Own A Audi A3 2007 (57)
    Got The Audi Nav Plus System In There Running Stock Speakers, And Had a Wiring Kit Added To It Today.
    Managed To Plug My Sub And Amp And Connect It All Up, However No Power To The Amp At All? Whyy?
    I Have A JBL7001
    Any Suggestions What It Could BE?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Presumably you have connected the remote 12v feed from the HU to the amp?
    This is needed to switch the amp on with the HU. The lead should be part of whatever wiring kit you have installed. Not quite sure how you've managed to install a wiring kit on the stock HU and not lose the feed to the rear/sub amp & speakers as they occupy the same connection. Far easier to take the feed from the new sub from the existing stock sub loom as everything you need is already there in the boot. You just need to run power from the battery.
    Alex Turner
  1. Help needed with an electrical issue. (Wiring Diagram needed)
    By Wiganer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 10:48
  2. Sub and Amp - Wiring
    By iyrix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2010, 16:43
  3. After-market Amp & Sub Wiring
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 16:53
  4. Amp wiring
    By otis_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th December 2007, 15:56
  5. Wiring Amp into S3
    By Jamesh in forum In-Car Entertainment
    Last Post: 20th January 2007, 19:49
