Revo TechnikAdrian S Flux
    Jun 2004
    Surrey
    595
    Post Thanks / Like
    Audi A3 8P speakers
    My friend has an 2008 sportback and is a basic spec and therefore has no speakers in the back doors. Is it possible to add these speakers, are they pre-wired? There is no option to fade to rear but assume the radio is the same, just coded? I think it's a chorus radio.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    You can add the speakers, but you will have nothing to drive them. The rears are driven by the tiny amp inside the subwoofer, which you also won't have along with the wiring loom to the sub/amp. So you would need to get hold of the non Bose subwoofer, rear speakers and more importantly the wiring loom from HU to boot. So not an easy job. You'd be far better off getting an aftermarket HU and then just wiring the speakers directly to it, or buy a small aftermarket 2ch amp and use that to drive the new rears. You should be able to pick up the stock rears on ebay, they are the same as the stock fronts - 6.5" components with a 1" tweeter. Ones from a B6 A4 will also fit.
    If you go with aftermarket speakers then you will need fitting adapters:
    Audi A3/S3 8P MDF front speaker adapters 6.5" component | eBay
    Alex Turner
  1. Need some new speakers to improve standard TV speakers
    By doublem_1 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 15th September 2011, 23:15
  2. Audi A3 rear speakers
    By SDO in forum In-Car Entertainment
    Last Post: 23rd April 2011, 11:12
  3. audi a3 rear speakers
    By robefc in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2011, 20:41
  4. audi speakers + sub problem
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2011, 18:20
  5. Audi A3 8P Front Speakers
    By RQ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2010, 20:46
