Thread: inverter
    14
    inverter
    i got an inverter to power my ps2.
    but i dont want to rip the car to pieces again to wire up a poxy inverter.
    is there anthing in the boot i can wire it up to. i.e interier lights. dont want to run the leads thru the car.
    Northern monkey
    168
    Re: inverter
    how about using the power for the sub ??
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: inverter
    Get another amp power lead witha fuse holder... run the power from abttery to sub, then clamp the new lead to the battery connector on the amp (with the powerlead from the battery) and then run it to the inverter... the other fuse is just to be safe. Best way to di it i reckon, but make sure the cable from battery to amp is up to the job... needs to be a afair old thickness.
    Rich
