    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    a3 front speakers
    what size are these speakers
    my front left one is giving a bit of distortion so i think i will upgrade the fronts
    what size and what speakers does anybody reccomend ??
    can i just straight swap them ?
    Jun 2003
    World of my own
    9,813
    Re: a3 front speakers
    They're 4" with 1" tweeters.
    They are a straight swap, but you'll need to use adapter rings or make your own from MDF as the OEM units use a 3 point fixing that sticks out from the speaker surround.
    You can either fit 4" components or go up to 5.25", but the depth is quite tight (only 60mm) so you'll need slim fit 5.25" units.
    Really depends how much you want to spend, I'd recommend 120 max.
    Alpine Kenwood or Pioneer for around 60-70, or Infinity Kappa's 50.5 for about 120.
    The downside of the Infinity's is that they're a pain to fit as they use prope crossovers which are really too bulky to fit in the doors so you may need to rewire them and mount the Xovers behind the glovebox. I'd recomend the cheaper units with inline Xovers, as you're driving the fronts off the puny amp in the HU, so you won't get the benefit of more expensive speakers unless you're adding an amp. Even the cheapest replacements will be a massive improvemen on the paper cone crap that Audi seem to think is all a 20k+ car deserves.
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    great - thanks for the quick reply andy
